My ST:TNG flipper has an issue. I first noticed the right flipper was not as strong as the left. For example I put my finger down "rather firm" and fire the flipper. It will just hit my finger and stop. Via settings, the "HOLD" wont lift the flipper. It wont lift the flipper for TOP RIGHT or BOTTOM RIGHT. At first I just figured, ok bad coil. But if TOP RIGHT and BOTTOM RIGHT are not able to "Hold" via test then something is wrong. Or will the right top flipper fail if the bottom right flipper is failing?
My Flipptronics board is a RottenDog. Long story short on a pinch a year ago I had to swap my ST:TNG flip-board with a brand new rottendog to get another machine to run.
However, in game. I can hold TOP/BOTTOM RIGHT flippers just fine. However, as I mentioned above the flipper has a hard time pushing weight. Like fast incoming ball for example. Not sure if I explained that well. Please let me know if I need to explain my situation better.
