Not sure how to proceed on this one. I believe (assume?) I have two seperate issues here:
1. The coil for the lower/center pop bumper on my Taxi does not fire in the game or in test mode. If I ground Q77 the coil fires so I'm assuming the transistor and the coil/wiring are fine. Do I just need to work my way back further up the board?
2. The top switch in the stack (closest to the spoon) doesn't register in game or test, however the bottom one will register in test. I tested the switch with my meter and I have continuity when it's closed. I noticed that that switch doesn't seem to be wired into the switch matrix, it looks like the two wires run directly to J18 on the MPU. I have continuity from J18 to the tabs on the switch, so I should be good there. Not sure what I'm missing here. Maybe something shorted to it at some point and there's a problem further up the board?
