So I got my Power supply and mpu repaired finally and got my game all up and running but there is an annoying issue with the Titan Tunnel shot.
If you shoot up the Tunnel, the ball gets stuck in the up kicker at the end of the tunnel and does not route itself into the ball save (3 for multiball). With the glass off I can hear the relay going nuts on the driver board (I think its the driver board) because the ball is stuck in there. I am pretty sure the coil tested out ok, what should be the tech path to resolve this? Consequently, if I take 2 more balls by hand and toss em up the ally they route properly to the ball save area and begin multiball minus the ball that is stuck in the kicker. The game recognizes I shot the ball 3 times up there but cant start/release the balls for the multi mode. :/ Also I got a dead upper mid pf flipper, I havent checked the capacitor yet.
Aaaaaaaany help would be appreciated. I have worked on gottlieb system 3 and pin2k but this is my first system11 and although it looks like the most simple pin I have owned from underneath, I am utterly fucking clueless!
THANKS
