Hi I have a gottlieb sweethearts game the thousand lite comes on at 900 so score will be 1900 until 100 more points will be added.Then it will read 1000 is there a adjustment or is it a relay switch any suggestions
Its a contact on the 100's reel. normally closes at 900 so the next pulse will energize the 1000pt relay. Im guessing its gaped too close and actually closes at 800. If it is truely closing at 900 then tabs on the 100s scoring relay, anything bent causing stray voltages?
Hi pinhead 52 you were right was the 100 relay one question I have a pop up bumper that. Sticks maybe 2 of them .Tomorrow I’m replacing the skirts any suggestion of were to look besides the coil switches .
Quoted from Ant16bar2:Hi pinhead 52 you were right was the 100 relay one question I have a pop up bumper that. Sticks maybe 2 of them .Tomorrow I’m replacing the skirts any suggestion of were to look besides the coil switches .
Sticks how? Like the rod and ring comes down and doesn't return?
If that's the case the skirt tip is probably coming out of the spoon switch and jamming the switch closed. The tip needs to be dead center in the spoon.
Well I took 100 point relay out adjusted it again and now the 1000 points works and no more sticky ten points pop bumpers I really think it was the bell coil sticking has to be
Quoted from Ant16bar2:Well I took 100 point relay out adjusted it again and now the 1000 points works and no more sticky ten points pop bumpers I really think it was the bell coil sticking has to be
Ten point bumpers have nothing to do with any of that.
This page was printed from https://pinside.com/pinball/forum/topic/sweethearts-game-problem- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
