Ok everyday I am learning a bit more about this machine. As I was planning out my list of replacement bulbs I found a few electrical issues.
When I ran the lamp tests I noticed several of the larger 906 bulbs that were not firing so I broke out the multimeter and tested the bulbs and all were good except one. I replaced the bad one with a good one. My next step was to check the fuses. There were two that I could see on the bottom of the play field and both tested good. I found one more that was in an inline fuse holder that to me looked like it was added later as some sort of repair? That had a blown fuse so I replace it. That seemed to fix a couple more of the bulbs that were in question but not all.
It also created a new mystery... One of the flashers in the back box (there are only 3 and one standard light bulb) stays lit continuously) and one on the atom smasher now stays on continuously as well.
There are still at least 3 flashers for 25k, 50k, and 75k spark bonus that do not light at all when testing or during play.
One last issue I discovered was that there is a 110v flasher relay board that controls the neon topper but as I discovered is also supposed to control the standard light bulb in the back box. Someone had disconnected the connectors and plugged the light directly into the power supply. As I watched a video on youtube (
#t=94 ) I noticed the main light on the back box had a slow flash to it. There is also fast sequence to it as well. The faster sequence seems to work fine but the slow sequence is nonexistent.
Any direction you guys could give would be great. I can add some pics if it will be helpful.
