Hi pinheads, I had a small problem today and wonder if you can help???
After finishing putting the playfield back together on the Shadow I cleaned all under playfield inserts, then I switched it on and problems started. The problem was not untill I'd worked under the playfield as far as I'm aware.
The machine asked me to check fuse 114 and 115, 114 had to be changed, only to blow again. After looking over the machine again, checking for bent over bulb holders, loose wires etc, a washer appeared and fell into main cab(I don't know where from).Now none of the ring lights would work and the start button and buy in button were not flashing right, nor was the O mongal light they were all extremly bright.
Going into individual bulb test, three times did 2 lights, light up together(I believe this shouldn't be), and in ordered row/lamp test it showed up that row/column 8 appeared to have the all these lamps, the four rings, the three over bright bulbs and a random arrow bulb.
I have checked the Q91 tp107 transistor against all its nieghbouring transtistors, and this one appears to give off a bad reading, I have ordered new transistors and have to wait now to see if it will be the fix.
Do you think I'm on the right track here or have you got any suggestions for me??????
