Yes I do have pinguy and I do use it, that's how I knew what level I maxed out at as I went dangerously to the top of the rear leg risers and all 4 of them are 3" from base of the foot to top of the bolt.
I've as I said had it from one extreme to the other, and it just seems floaty up top where it'll bang around for awhile in the pop bumper area, and above there in those 4 lanes it'll do a slow bounce repeatedly off the rubbers there usually many times before it settles between one of them (it doesn't just like bounce one maybe two times and slot into there.) That's why I was wondering if there was an ideal setting.
One thing I've noticed that does change depending on the angle is how it can go to being super common more than once a game where the ball will hit the bumper above the right flipper which will sling it over to the one on the left which is unpowered, but the ricochet will pocket it into that right outlane which gets infuriating when it can happen like 3-4x a game on a 5 ball game. The elevation has affected that, but not the top. I don't mind speed, but I don't like it floating so much if it wasn't intended to.
