I have read quite a few posts on this but still haven’t figured it out.
I have a 1973 Williams triple action. The score motor keeps running at startup. I have cleaned the entire machine including all stepper units and score reels etc. and all contacts. When I remove the john plugs to the playfield the motor will stop so I figure it’s a stuck switch. I went back and cleaned all contacts and checked every switch and coil. Still runs. So this is what I know:
When a ball is in the drain and i power on, the score motor will run continuously. When a ball is not drained and I power on it will run a rotation and get set. Then if I hit the start button everything resets, the reset relay is stuck in power on and the motor runs continuously. Then if I manually pull the reset relay to deenergize, the game is functioning but score motor still turns continuously. Also, when I had the playfield completely removed, the score motor functioned properly but then again a lot of stuff was disconnected.
So, is there something besides a playfield switch I should be looking at (I believe I cleaned and set them allgood enough), or can the reset coil or ball drain cause the motor to run. Or am I looking at tracking wires to look for a break. Any suggestions are appreciated. Thanks
