Having some issues. I'll post here before making a thread. My diverter won't stay open when in lock mode. It's as if there isn't enough power to hold it. Coil looks good. I did order a new coil plunger but I doubt thats it. It works for the first ball but once the game is going stops working. Mechanically it operates freely with game off. The crate post hold works fine. I read someone fixed be replacing the ribbon cable from the mpu to the power board or someone else fixed by reseating the asic chip which seems strange. If in lock mode and the ball drains, the diverter will quickly lock open for a couple seconds, then close. Once the next ball kicks out it will open as it should but then close as if there's not enough power to keep open. I don't have a replacement coil to swap but I don't think that is it. Take a look at this ribbon cable. What is the heavy weight attached to it? Any advice would be great.
