OK...lets get more data.
You need a length of wire without clip leads on both ends.
Clip on end to the tab of Q8. This transistor turns on the A/C select relay.
Clip the other end to game ground, like the ground braid.
Power on.
You should hear the AC select relay click as you've provided a path to ground for the power waiting at that relay.
Now enter coil test.
Coils 1-8, should fire either the A side twice, or the C side twice. I don't recall the "sense" of that relay. After firing coil 1 twice, it will move on to coil 2.
Watch and listen carefully. Does a coil for each coil number fire twice?
What we are trying to prove is that the AC relay works.
After gathering that data, turn the game off.
Remove the clip lead attached to ground.
Reboot.
Once the game gets into attract mode, briefly touch the free clip lead to ground. Do you hear the AC select relay click?
Get back into test. Start coil test.
Listen to and feel the AC select relay. For coils 1 thru 8, do you hear or feel the relay click?
Chris Hibler - CARGPB #31
http://www.Team-EM.com
