(Topic ID: 204056)
Pinsound Volume Adjusting Help
By bobwiley
6 years ago
  • 18 posts
  • 8 Pinsiders participating
  • Latest reply 2 years ago by turbo2nr
  • Topic is favorited by 8 Pinsiders
    #1 6 years ago
    I'm putzing around with a Pinsound Studio and trying to balance out individual voice callouts, sfx and music volumes. I already used audacity to maximize the native voice call outs when converting them to .wav. When I load the mix into Pinsound Studio only a few of the file folders show up and Pinsound just plays them in a row really fast. Any tips or tricks?
    #2 6 years ago
    Figured out a little bit about volume. Pinsound will create a text file called "gain" that contains a number to adjust all the sound files in that specific folder. So if you want a specific sound to be louder, and it is the only file in that folder, the "gain" text file will just have "20" or some other volume that you can set in Pinsound Studios or manually create in the folder. If you have several files in a folder, the gain will be applied universally. Also, you can set it in folders, such as "voice" "sfx" "jingle" or "music" and all the files in those underlying folders will be set with said gain setting.
    Audacity does have the ability to "normalize" several files so their volumes are relatively close, so hopefully multiple files in a single folder will have about the same level of loudness.
    Still can't get Pinsound Studio to show all the file folders though...
    #3 6 years ago
    Quoted from bobwiley:
    This feature will be in the next release, working on it
    6 months later
    #4 5 years ago
    Wasn't sure where to post - so this was the closest. When my Pinsound boots the startup boot.wav is way louder than the ingame sounds. I want to reduce the volume of that but its unaffected by the in game sound volume setting. Any tips? The Pinsound website doesn't have much helpful info in terms of controlling it.
    #5 5 years ago
    Quoted from Junglist:
    You could just edit the boot.wav file itself to be a lower volume. Audacity is a free audio file editing tool which can do that easily.
    8 months later
    #6 5 years ago
    Thanks for posting. I just put a PinSound in my Guns N' Roses and the music is much louder than everything else. I'll have to mess with this!
    1 year later
    #7 3 years ago
    +1 for lowering boot.wav in Audacity
    #8 3 years ago
    or just make your own custom boot.wav file
    1 year later
    #9 2 years ago
    If no gain file is present, then what is the default gain value?
    If I set gain to 2 in text file, is that louder or more quiet than if I have no gain file?
    Also, what is the range of this value? 1-??
    What is max gain value? 20?
    After sound package is installed...I am adding and changing this text file and I do not hear any changes! ??
    Tried adding this text file with 2, 6, 12, 20 and then reboot and the One music file seems the exact same to me.
    Scott
    #10 2 years ago
    Can we go negative??
    Gain = -4 for example?
    Can we have more detailed info on this please?
    #11 2 years ago
    Ejected usb flash from game.
    Changes to the gain files do absolutely nothing.
    Had a great time wasting yet another half hour on pinsound.
    I guess these changes need to be made before unzip and the initial install of sound package?
    #12 2 years ago
    PinSound
    Can we edit gain value after sound package is installed?
    Pull out USB and create a gain text file in folder, then put USB back into game and boot.
    Because for me I do not notice any changes at all.
    Thanks,
    Scott
    #13 2 years ago
    I log in to community forum on pinsound site.
    Type out my new thread and submit.
    The F'n thread never posts!! Just hangs-up and I cannot create a new topic.
    Does everything related to pinsound just suck? Hardware is good! Support, instructions, discussion is the worst.
    #14 2 years ago
    Your forum is broken! Cannot make a new thread for support.
    #15 2 years ago
    Someone asking similar questions as me years ago.
    NO REPLY! DEAD THREAD! ??
    So, I guess it doesn't matter if my question/thread is created? Nobody would bother to answer I guess?
    Excellent support Pinsound guys! The best!
    #16 2 years ago
    This is my 3rd time trying a pinsound board (and my last!!)
    Horrible support! Incomplete instructions.
    Anyone want this POS? I'm selling it.
    Scott
    #17 2 years ago
    We just received your email, thank you for reaching us directly (as we cannot scan and check all the forums every day). We usually reply to every support request within 24h.
    I'm sorry you experienced this issue, we just sent you a complete response by email.
    As it might be interesting for other PinSound users:
    Gain.txt: this file format description to change the gain is not supported for a very long time. The correct way to change a gain of a specific sound is through the PinSound Studio Pro. You open the sound pack in the software, you locate or search for the sound you want to modify, you choose the gain and you save your sound pack. You can put the flash drive back to the sound board and you're all set.
    Config.ini : this file format is not used anymore. I'm deeply sorry you've been confused with old configuration files that are not supported. Everything can be defined in the PinSound Studio Pro with improved and new features.
    USB flash drive: the thumb drive must stay connected in the sound board.
    -> https://www.pinsound.org/products/pinsound-studio-pro/
    #18 2 years ago
    Can't create a new topic/thread on you community forum.
    There is no good updated manual or instructions. I am sick of wasting my time once again on this product. It's the Third game and Third time I try your product. It will be my last time also.
    My time is too valuable to waste on this!
    Maybe one day you make an actual manual to download for owners to read? Maybe not? At this point I no longer care. Back to original DCS once again for me.
    This page was printed from https://pinside.com/pinball/forum/topic/pinsound-volume-adjusting-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
