Hi, I'm looking at a friend's Fish Tales and what I once thought was a simple diode issue, is actually on the mpu and has me a bit confused.
Rather than just buying and shot gunning the matrix chips, I thought I'd see if anyone has encountered this before. I'll get over there with a logic probe soon anyway.
At this point, with all the switch connectors unplugged from the mpu, this is the behavior.
If any switch in column 1 is closed, AND 41, or 51, or 61, are also closed, a switch will register on the same row as the closed column 1 switch, on column 4, 5, or 6.
Examples
if 14 is closed, 41 will trigger 44 and 41
if 16 is closed, 51 will trigger 56 and 51
if 18 is closed, 61 will trigger 68 and 61
if 15, 16, and 17 are closed, 51 will trigger 55, 56, 57, and 51
ect.
This only happens with 41, 51, 61 and only in combination with any switch on column 1.
I just thought I'd see if this is a failure any of you have seen before. Thanks!
