So I'm trying to isolate a no boot, no LED flash, I plan on repining the board and redoing the connectors but trying to see if the solenoid board is any good first. All the high voltage points are good, but both 5v's are dead, and when I checked the 11.9 it was good. As a temp fix I pulled the board, reflowed and brass brushed the pins, I burnished all the females and put it all back together, and again have the same thing, 0 on the 5v's and 11.9 on 5, but then I watched the tp5 go from 11.9 all the way to 0, and now its dead too. High volts are all still good. Is this the c23 c29 c24 or the e-710 maybe, I don't want to just throw a bunch of parts at it, or could this just be a pin and wire problem?
PS all the rectifier points read good, before and after the voltage drop on tp5
PSS right before I went to post this I said, ah hell, lets check the back of the 12 pin and see if there is juice, and there was, 11.9 and saw a little spark when I touched the back of the lead, stuck a toothpick in and TP5 is holding at 11.9, (yes I know this is not a permanent fix but still dead on the 5v's
