Anyone have a Big Daddy Enterprises 6116 RAM adapter installed instead of using batteries? If so could you send a pic of how/where it's installed and some feedback on if you like it or batteries are better.
Thanks all.
Here is the link incase you have never seen one: http://www.bigdaddy-enterprises.com/
Hi, I do not know the adapter from bigdaddy, but we produce 6116-RAM-Adapters since many years and have therefore "some" experience.
But as I suppose, the bigdaddy RAM-Adapter supports the following pinball-machines, that use 6116-RAM-chips, as this are some early DATA-EAST-pinballs, Williams System 11 pinballs, Bally MPU A084-91786-AH06 (6803) (used by Bally Midway, Bally Wulff und Midway) und some others. I think, it does not work on a Williams system 9 game (e.g. Comet); therefore you need another 6116-RAM-adapter-hardware.
To answer your questions:
1.)
RAM-Adapters are very useful, because you will never ever need any batteries with all disadvanteges (e.g. acid damage, buy new batteries every year).
2.)
Installation is very easy, as far as the original 6116-RAM is already socketed. If not, you must first desolder the old RAM (carefully), then in a 24-pin (precision) IC-socket. Then take out the batteries and put in the RAM-Adapter. Please be carefull, to put it in the right way. You must first locate PIN 1 of the original RAM.
The put in the RAM-adapter the same way, so that PIN 1 of the adapter is in the same position as PIN 1 of the original-RAM. Do not put in the wrong way, otherwise, the NVRAM on the adapter will be destroyed. See attached files of where PIN 1 is. On our adapter it is silkscreened on the top left side and it is the same on the bigdaddy-adapter, as far as I can see on the pictures.
See attached files:
