Hi,
I have a question about mylar uplift on the playfield. I have a system 11 machine that came with mylar installed on the playfield when I bought it. I hadn't paid much attention over the years, but it came to my awareness that the mylar appears to be lifting around most of the inserts. I've read a few threads that say to leave it alone unless you have experience in removing mylar. But I haven't seen any threads addressing my specific question, which is this: if I simply ignore the mylar lifting around the inserts and just live with it, will it get progressively worse over time? In other words, will it continue to lift past the insert areas and eventually effect the remainder of the playfield over time? Or will it stay localized only to the insert areas?
