Quoted from Thunfisch:Where in Europe?
Oh, I see. Sorry, that's too far away....
Quoted from Thunfisch:Oh, I see. Sorry, that's too far away....
It's far...but I can send a transport agency if the purchase is good...regards
Upper Drop bank is a bit flaky on mine. When game starts, middle three targets pop up. Then when middle gets hit it doesn't come back. Randomly drops will come up then drop scoring and moving to next target. Sometimes they come up amd stay up other times not.
What to do, what to do??
Quoted from Dwboca:Upper Drop bank is a bit flaky on mine. When game starts, middle three targets pop up. Then when middle gets hit it doesn't come back. Randomly drops will come up then drop scoring and moving to next target. Sometimes they come up amd stay up other times not.
Do all the drop target switches register properly in switch test? Make sure to reset all targets and remove the balls before beginning the test (that way you won't have to wait for it to cycle through all the other active switches over and over).
Might be worth getting a closer look at the drop target switches regardless--they may be out of adjustment or in need of cleaning (or both)...
Looking over the rules, it looks like the center target is raised first, once that's knocked down 2 more pop up. Same happens again for 3, then 4, then 5 (which upon completion lights Double Trouble)...
Quoted from frunch:Do all the drop target switches register properly in switch test? Make sure to reset all targets and remove the balls before beginning the test (that way you won't have to wait for it to cycle through all the other active switches over and over).
Thanks, for reply.
I'll do these things and reply back.
I created a new post but figured I’d add it to the club post as well. Hoping someone has seen this before and can help. Appreciate any tips.
I have a Jungle Lord giving me fits. It had a flakey power supply which I replaced with a new one from pinballpcb.
Now I’m down to one set of issues. All items plugged into j12 do not work. This is the special solenoids and flippers. Solenoids include lower slingshots, upper sling, both magnets and the mini ball kickout. All other solenoids and switches work fine.
What I’ve done so far:
-Grounded each transistor to get the solenoids to manually fire and they do work
-tested the pre driver and they were all good
-tested the tip 120/102 and they were good
-tested the 7408, 7402 chips and replaced the pia chip with a known working
-reflowed the 40 pin male/female connectors
-checked all fuses including the under playfield fuse
-Checked bridge rectifier
- the switches do NOT register in switch test
-banged my head on the backbox and still nothing
A previous owner has replaced or reflowed a lot of what I tested I’m guessing to try and fix what I’m struggling with. I’ve followed all the steps on pinrepair for this issue and have reached a point where everything checks out but still nothing.
Aside from sending my boards off, what else can I check? I appreciate all the help. I’m still new to solid states so please take it easy on me.
Available for the first time in years from Planetary Pinball Retail! Jungle Lord Reproduction Mirrored Back Glass R-8552-503M. This is a master class mirror using a real silver mirroring process with lots of mirroring in the glass! Same manufacturer as our acclaimed Cactus Canyon and Medieval Madness remake back glass. Color matched to the original. Replace that damaged Jungle Lord Back glass today.
jungle lord-(Front) ebay (resized).jpg jungle lord (back) -ebay (resized).jpg
Quoted from PPS_Parts:Available for the first time in years from Planetary Pinball Retail! Jungle Lord Reproduction Mirrored Back Glass R-8552-503M. This is a master class mirror using a real silver mirroring process with lots of mirroring in the glass! Same manufacturer as our acclaimed Cactus Canyon and Medieval Madness remake back glass. Color matched to the original. Replace that damaged Jungle Lord Back glass today.
[quoted image] [quoted image]
Man i wish these were available when I had my Jungle Lord!
This page was printed from https://pinside.com/pinball/forum/topic/me-jungle-lord-club/page/5 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
