First off, I'd like to apologize for my ignorance here, but please bare with me. I am trying my best.
Ok, so I'm trying my best to test this machine with my limited to no knowladge.
Here are the list of things that I have been suggested to try:
[list]1 - Check the connection to the CPU board one at a time.
2 - Check the transformer.
3 - Disconnect everything from the transformer and test voltages, plug in psu and check voltages, continue down the list.
4 - Check for burnt connectors.
5 - Check the transistors (Driver and Pre-Driver) Possibly 74...04.
6 - Check the IC and PIA[/list]
This all make very little sense to me, I'm about 2 hours into this hobby for repairs.
I have a MultiMeter, Analog
[url=http://imageshack.us/photo/my-images/713/photobiu.jpg/][img]http://img713.imageshack.us/img713/3348/photobiu.jpg[/img][/url]
And I'm not sure how to even use it. I don't even know where to put the leads, or what settings to use.
#1 - I'd like to avoid testing this until I find out why the fuses keep blowing in the PSU. (Unless you think I should check this anyways)
#2, #3, #5, #6 - With respects to 2,3,5 and 6, these all require that I use the MultiMeter. I assume for checking different things, would require different settings on the meter.
Specifically with regards to #5, which settings would I set the meter to, in order to test the transistors?
[quote]2d. Before Turning the Game On: Quick and Easy Transistor Testing.
Before ever turning on a new DataEast/Sega game, test all the TIP122/102 solenoid transistors. Do this while in the backbox (examining the fuses and the GI connectors). A blown transistor can really confuse a game. This is the procedure to use, and it only takes about 60 seconds to test all the TIP122/102 transistors:
Make sure the game is off.
Put the DMM (digital multi meter) on ohms (buzz tone).
Put one lead on the ground strap in the backbox.
Touch the other lead to the metal tab on the TIP122/102 transistors.
If zero ohms (buzz) is shown, the transistor is bad! (shorted on).
There are a number of TIP122/102 transistors on the DataEast/Sega CPU board:
Q8-Q13: located at the upper right (special coil transistors).
Q23-Q30: located at the lower left (constant power transistors).
Q39-Q46: located at the lower left (multiplexed transistors).
Q72-Q79: located at the lower right (lamp matrix return rows).
Replace the bad TIP122 transistor(s) with a more robust TIP102 immediately before turning the game on. Replace the associated pre-driver 2N4401 transistor too.[/quote]
#4 - With regards to #4, I've checked for burnt connectors, and I can only seem to find one, that I think is burnt.
[url=http://imageshack.us/photo/my-images/338/photo1csz.jpg/][img]http://img338.imageshack.us/img338/2702/photo1csz.jpg[/img][/url]
#5 - I'm not sure which transistors you are referring to (74 to 04).
#6 - Not quite sure what these even are, where to find them, or how to test them.
I hope I didn't miss anything.
I guess I have the worst luck, most issues are very specific, where as mine is quite vague. The machine will not boot. As far as I'm concerned it could be ANYTHING!
Thanks again to any one who can offer me some insight here.
***LET ME KNOW IF YOU NEED PICTURES OF ANYTHING SPECIFIC!***
