Le style listed below second vid. First vid is the plastic apron upgrade. Quick easy add on for any plastic pro apron owner or anyone that has upgraded to an LE style. The emblem will work on both 2010 versions and the 2014ve version. The only tool you need is a 1/2 drill bit or larger to mount the EL panel. This emblem matches my pop bumpers and is lit constant if the machine is on. It can be tied to an insert lamp (runs on 5v-7v) to come on during game play. I prefer it to be on constant and that is what is shown in the vid. Also these can be added to speaker grills if you want to modify the grill. They will be for order on my site next weekend but wanted to post here first. The Vid shows the basic install and a live test run. One thing to note is the test run is not installed onto the playfield whereas mine has the LE metal type mounts...installed just for pictures.
Pro upgrade price will be $54.95 or $89.95 installed on a pro apron (only have 3).
Pro upgrade now on my site along with the other options - LE being built out now.
Vid of LE lower on thread.
If you have a raw apron and just need art work and wiring contact me.
Check out all of my mods at Hookedonpinball.com
