I've been chasing this problem down for a long time, but I still can't seem to get them working properly. Most recently, while playing a game, the right flippers stopped working. I kept the flipper button held down, went to switch test in the diagnostics, and the switches were not showing up on the switch test. Tried hitting the flipper button a few more times, still nothing coming up on the switch test. Finally they started working again, and would not act up! Here's what I've done so far:
-All EOS and flipper switch wires test good from switches to connector for Fliptronic board
-Installed new flipper switches
-Replaced EOS and flipper switch connector pins and housings on Fliptronic board
-Re-flowed solder to EOS and flipper switch header pins on Fliptronics board
-EOS switches were replaced when rebuilding flippers, all test good with meter
After trying all this stuff, I'm still getting occasional intermittence from both right flippers and the left flipper--the strength of the flippers seems to fluctuate a bit too. They typically will start acting up within 1-3 games.
Any ideas?
