I'm sure this has been discussed elsewhere but I have been unable to find it on Pinside.
I recently started routing a Hobbit and ended up recently with two errors on the Orc. First one was that I had was a wire binding up and physically keeping the Orc from popping up. That was a pretty easy fix once I lifted the playfield and inspected. The next is that the Orc hit-switch still will not register. The switch is not stuck closed and all the connections on the switch and diode look fine in appearance. As I had to get back to my day job, I simply disabled the Orc for now so the game will still be playable.
Any thoughts and suggestions are appreciated.
Thanks,
Darin
