I've brought a few old pins back to life but this issue has me perplexed.
As this pin came back to life it worked correctly for 10-20 games. Then it started having an issue latching the game over relay when ball 5/ball 3 drains with 1 player or 4 players selected.
The game starts correctly and plays correctly. The Game Over relays latches with initial power on and never has an issue latching closed.
But when you play a game and ball five drains the O (Ball return) and Q (Game Over) relays pulse as the score motor turns. The relays do not pulse with the B score motor teeth (this reel has the most teeth on it), they chatter faster than that but not at a full 60Hz.
All relays in good condition and replaced as required.
All relays in the cabinet are adjusted correctly and contacts cleaned. The score motor was disassembled and all contacts adjusted and cleaned.
All contacts properly gapped and cleaned for Q (Game Over), O (Ball Return), BX (Last Ball), FS (00-90), Coin Unit including contacts 0 position. The associated Game Over string is found on 14E of the schematics.
The playfield voltage to the pops, kicks and flippers is rectified but the cabinet voltage is not.
Any ideas would be greatly appreciated. Not sure if I have a bad diode somewhere allowing a voltage to bleed through. But if this was the case I would assume other random issues would also occur.
