Quoted from mdo1998:does the EOS play any role in advancing the score reel, meaning could my new EOS be the cause of the score reel not fully advancing from 8 to 9?
frenchmarky described this in reply #10. The EOS switch on any score reel is intended to keep the current running through the score reel coil until the plunger is pulled all the way in:
Point relays are often driven by momentary switch closures on the playfield. Switches behind targets, rebound rubbers, under pop bumpers, etc. close very briefly and may not activate the point relay long enough for it to energize the score reel coil and fully pull in the score reel plunger. So point relays (and many other relays) used what's called a Lock In circuit to extend how long the relay remains active. In the example above, any 1000 point target (not shown) can activate the L/1000 Point relay. But once activated, the L relay closes its own Lock In switch (labeled "L") to keep itself on until the EOS switch on the score reel (here labeled "On Add 1000's Unit") opens and lets the 1000 point relay relax.
It's a feedback mechanism where the 1000 Point relay sends current to the score reel coil until the score reel lets the 1000 Point relay know that it has done all it can do (pulled its plunger all the way in) and doesn't need any more current.
If the EOS switch is always open, you don't get the extended pulse width that the Lock In circuit provides. You're left with a pulse to the score reel coil that's only as long as the playfield switch is closed which may be enough, but isn't reliably so.
If the EOS switch were a problem I'd expect to see the score reel occasionally fail to advance on any digit not just 8 to 9. More likely the score reel is having trouble closing the 9th position switch. There may be some extra friction in the score reel or too much tension on the 9th position switch.
For more details about how score reels and lock in circuits work you might want to watch a seminar that David Volansky and I presented last month at GSPF:
We explain, build and demonstrate scoring circuits from the ground up with real hardware.
