Hi,
I have the same problem as the member here
https://pinside.com/pinball/forum/topic/funhouse-rudys-eyes-stay-locked-shut
He found a workaround where I would like to find a proper solution.
The problem is the following: Rudy's mechanism to open and shut eyes is ok. The only problem is that the shut eyes plunger goes too far when released. The open eyes plunger, in release position (high), is bend at the max against the metal. When the coil is triggered, it can cannot attract the plunger. Even manually, I cannot lower the plunger into the coil.
If the horizontal plunger (eyes closes) was not going that far, it would work fine. I checked it by pushing it back a little bit. And the vertical plunger moves down easily.
I noticed the following : I guess there are two open positions for the eyes, widely open, or normally open. When Rudy needs to widely open eyes, the coil manages to open them, but after that it goes back to closed eyes, instead of staying to the normal open position.
I do not want to make a trick to stop the eyes shut plunger. Is there any solution that you could provide ? Is this issue kown by more than 2 people now ?
