I have had this idea for a while now, but man I can be lazy.
So everyone has a trick on the easiest way to adjust leg levelers to level out a game. Crow bar, use a cart or your back. Anything to get the weight off the leg so you can turn it.
I've tested this on standard WPC, EMs, and Sys11 games. No issues. Haven't tried it on widebodies, Sterns, Bingos, etc
Well this is what I came up with. It's easy, and won't cost you a thing (unless you don't have a dremel an or cutting discs)
What you need:
Dremel
Cutting discs. I get em cheap at Cardboard Freight. They get the job done and are way cheaper than anywhere else
Vise
Safety equipment. Goggles at minimum, although a painters mask is a good idea. Lots of small metal will be flying, and you don't wanna breathe that in.
You are going to cut a cross into the top of the leveler, so that you can use a socket wrench and a Phillips head attachment to allow you to turn the leveler. You only need to cut down about a 1/4" or so. The cuts don't have to be perfect, just good enough to accept the attachment.
It works, and works well.
