(Topic ID: 63718)
Drilling Tron Ramps
By DrStarkweather
10 years ago
#1 10 years ago
Just wondering to those out there who have done ramp mods to their Tron already, whats the best method of planning the drill holes on the ramps? Im going every six inches or so, but I want to make sure they are tight and hugging the curves. So it doesn't look sloppy. Anything you would have done differently?
#2 10 years ago
I've read that melting the holes with a soldering iron is a nice, clean way to do it, but I haven't actually tried it.
#3 10 years ago
Others have recommended a dremel, but I have not done it, I taped my ELwire on, will try the dremel when I get ELI's mod...
#4 10 years ago
Iv got the method set. Iv used the soldering iron before and find the holes 'cleaner' when you drill. I guess Im more wondering about hole placement? How to keep the wire tight and anything you would do over if you could. You only get 1 shot after all.
#5 10 years ago
Perhaps someone could post some pics of their LE and highlight all the zip tie points, Id add a few extras in the inner curves. Good luck Dr.!
#6 10 years ago
Quoted from DrStarkweather:
I head Stern will happily replace your ramps if you screw it up. Just kidding
#8 10 years ago
I watched B_R-The Man! Great video-take ramps off completely then place scotch tape for layout on holes to be drilled.
Pics_3-2013_006.JPGPics_3-2013_006.JPG Pics_3-2013_008.JPGPics_3-2013_008.JPG
#9 10 years ago
you can use tape and you hardly even notice it!!
#10 10 years ago
ok... ok...
here's an LE
photo-21.JPGphoto-21.JPG photo-20.JPGphoto-20.JPG photo-18.JPGphoto-18.JPG photo-17.JPGphoto-17.JPG photo-16.JPGphoto-16.JPG
#11 10 years ago
and...
(someone needs to clean his playfield)
photo-13.JPGphoto-13.JPG photo-14.JPGphoto-14.JPG photo-15.JPGphoto-15.JPG photo-12.JPGphoto-12.JPG
#12 10 years ago
These may be to late (but better late than never 8-})
No such thing as too many photos.
http://s737.photobucket.com/user/Pin_-_K/library/TRON-LE%20RAMPS%20-%20TYE%20WRAP%20LOCATIONS?sort=3&page=1
Pin - K
www.KimballsPinballs.com
#13 10 years ago
I had started but held off on the drilling more till I got some responses. Thanks for all of this. It seems I have so far drilled LESS holes than Martin's guide but around the same as the LE. (and Kimball's I think is the LE too?)
I'll watch B_R's video and maybe pick up some scotch tape (thought about doing that already but had none in the house. My instincts were to use as little zip ties as possible for a clean look. Maybe there is a happy medium between tape and less holes?
#14 10 years ago
I have the kimballs el set, the tape has held ok but it is starting to look slightly loose in spots, so I will FO SHOW zip tie when ELI's mod gets installed on my baby.
#15 10 years ago
These are the pre-cut mounting tape that I send out with the TRON Sound Activated EL Wire Ramp Kits:
http://www.scotchbrand.com/wps/portal/3M/en_US/ScotchBrand/Scotch/Products/Catalog/~/Scotch-Pop-Up-Tape-Refill-Strips?N=4335+3294603612&rt=rud
Drilling is probably the best long term solution but when the Tape is applied very tightly to/around the EL Wire & then to the Ramp it has held surprisingly well - so a significantly easier way to go if you're not ready to completely remove & drill your Ramps (or as a prelude to figuring out where to drill 8-}).
With the FO being a larger diameter (+ having significantly more weight & mass) not sure how the pre-cut tape would work.
Pin - K
http://www.KimballsPinballs.com
#16 10 years ago
The fiber cable has a nice super slick Teflon (well, PTFE actually) jacket. Tape might be tricky, except where you can force the fiber into a bend with zip ties, and use the tape to hold it there.
#17 10 years ago
nice, just go for it. measure twice, drill/cut once. have fun and love pinball
$ 6.00
Playfield - Plastics
Minty's Mods
$ 64.00
Lighting - Under Cabinet
$ 200.00
Professor Pinball
$ 350.00
Professor Pinball
$ 50.00
Duke Pinball
YouBentMyWookie
$ 135.00
Dijohn
$ 11.95
Trade
$ 109.95
Hookedonpinball.com
$ 24.95
$ 8.00
Minty's Mods
Filament Printing
Lighting - Backbox
$ 99.00
PinballReplacementParts
$ 9.95
Mitchell Lighting
$ 40.00
Disk war combatant Pre-order!
RamMods
10,250 (OBO)
Willington, DE
YouBentMyWookie
$ 14.95
Mitchell Lighting
PFX Pinball Mods
9,000
Charlotte, NC
This page was printed from https://pinside.com/pinball/forum/topic/drilling-tron-ramps and we tried optimising it for printing. Some page elements may have been deliberately hidden.
