Hey guys I ran a test on my williams IJ and it says there's a bad coil. How do I find the coil that's bad ?
What does the DMD say ? It usually doesn't mean a coil is bad, it usually relates to switch issues.
You can better help if you post what comes up on the DMD.
Thank you,
Lloyd
I'm also having a very hard time getting the ball to stay in the mode start hole it always bounces out of it. How do I get the ball to stay in the hole
try some foam rubber on the metal the ball hits and see if it deadens it and stops bouncing out.
Single drop target near the upper right side. It's switch isn't working.
When the target is down it pushes the switch closed, when up it releases the switch and it opens.
Check the switch for broken wires, diode, that the arm is there, and then see if the target push it when it goes down and lets it up going up. Could be assembled wrong or something broken. Make sure target goes up and down smooth.
Check in switch edge test.
This page was printed from https://pinside.com/pinball/forum/topic/coil-problem-ij and we tried optimising it for printing. Some page elements may have been deliberately hidden.
