Renovating a T2 machine that lacks a coin acceptor. I guess that it is possible to make it work without a coin acceptor, for now I'll just put it on free play. Should I simply don't connect the wires going to the coin acceptor and let them hang loose? Or should they be connected to eachother?
Actually the same question goes to the slam tilt switches and the coin chute lamps.
The 13-pin connector on the coin door interface board is only connected to the control panel on the door (the 4 buttons to enter setup menu etc). All other wires that goes from that connector (coin acceptors, slam tilt switches and coin chute lamps) are cut off.
If I dont want those things, how do I wire to "bypass" them so that the game will work without them?
