While my BOP sat through most of the pandemic, I did change the batteries annually. On this most recent change, however, I noticed both flippers stopped working. The batteries are easily accessible so it didn't seem likely I disturbed anything. I checked the EOS switches and the button area all looks good there. At that point, I figured it'd probably be a fuse but unlike PinBot with a single slow-blow, BOP has F101 and F102 for Left/Right...which made it strange both would go out at once. Sure enough, both fuses look good and none of the others appear blown.
At this point, what else could it be that's a shared location causing both to go out at once? The original Pinbot had an obvious power supply board but the Bride doesn't seem to at a glance of the manual. Still, there has to be something shared between them. Any tips on what to check next are appreciated.
