Bride of Pinbot 2.0
However, it sometimes happens that the Flipper Fingers simply switch off in the game.
Now found out that happens just when a switch is hit.
Which switch does not matter, it happens everywhere.
On the video you can see it at the end.
The entrance switch of the cardiac ramp is still running, then the flipper fingers fall off at the heart exit switch and are dead. With the next ball, everything goes again.
The error occurs only in Bop2 mode, if you select the original game of Williams, the device runs properly.
Have checked all the switches and some exchanged for new ones, swapped USB cables and tried on various USB ports.
Find no solution to the problem.
Have ordered in my desperation even a Rottendog Powerdriver Board, but do not think that it is because in the original mode is all right.
I'm grateful for every little tip.
Greetings Peter
