Good day.....I have a BK2000 and the wiring under the upper small playfield is "loose" and needs bundling but right now a harness is
getting mashed on top of one of the metal guides on the playfield below.
Could anyone post a photo of the underside of the upper playfield for me to use as a reference to see where I should tie up some of the wires
from the harness in order that they won't get mashed on the lower steel guides underneath?
A previous owner just forced the upper playfield down in place and now some of the wiring has been pinched or has insulation cut/stripped from
rubbing on the metal guides.
John
