It seems like one thing goes and the rest follow. I replaced the micro switches in the batcave and they work just fine. Now the tech alert shows #30 Switch stuck open in batcave.
I checked the wires to the switch and playfield, all were connected. When I did a switch test the batcave exit switch didn’t register closed, only open. When I removed the switch and the tech error went away. I am assuming the switch is bad so I ordered a new switch.
Has anyone else had this problem before? Do switches go bad?
