(Topic ID: 179686)
Bally Mystic ~ flipper relay won't fire
By schmoo
7 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by schmoo
#1 7 years ago
I have swapped in several good relays and none of them are working.
I have replaced the Q15 components which drive the relay. Grounding Q15 does not activate the relay nor does it fire during the solenoid test.
The SDB worked fine ( including flippers) when it was in my Bally Hottdoggin so I'm thinking it's MPU or wires.
Looking for a list of places to look starting ( obviously) with the most likely culprit(s).
#2 7 years ago
start checking the connectors between MPU and SDB.
#3 7 years ago
Quoted from schmoo:
Double check. Did you replace the 1N4004 diode CR15?
#4 7 years ago
Quoted from vec-tor:
Yes, I swapped out CR15 when I did Q15.
#5 7 years ago
Quoted from wdennie:
Started my search with SDB J3-5. I am getting continuity between it and the transformer J3-9, but unlike the transformer, I am not getting 44 VDC. Should SDB J3-5 be showing 44 VDC ?
$ 12.00
Tools
Nezzy's Pinball Prints
$ 44.99
Pinball Shark
$ 9.95
$ 119.95
Allteksystems
3,200 (OBO)
Franklin, VA
$ 18.00
Cabinet Parts
Volcano Pinball
$ 18.95
$ 22.50
This page was printed from https://pinside.com/pinball/forum/topic/bally-mystic-flipper-relay-wont-fire and we tried optimising it for printing. Some page elements may have been deliberately hidden.
