I'm working on putting an EBD back together that has been apart for awhile. I have two SDBs that both test well in the machine when NOT connected to the MPU.
On the SDB: TP5=15.1VDC, TP2=5.2VDC
However when I connect J4 on the MPU (and only J4) I get on the MPU: TP2=15.1VDC, TP5=.5VDC, No light on the LED.
At the same time the SBD TP2 also drops to .5VDC when the MPU is connected. These numbers seem to remain unchanged when the rest of the MPU connectors are connected.
I tried a separate SDB and get basically the same results. I don't know for a fact that either SDB works correctly 100%, but the two relative test points check out fine when not connected to the MPU
The MPU separately tests well on the bench with computer supplied 5VDC and 12VDC.
Any other things I should be checking at this point to identify what's going on and causing the 5VDC to drop so much?
Thanks,
Vince
