It doesn't have green wire, BUT... I closed it..., after opening it 4 days ago..(Dumb new EM owner). I thought it was one of the tilts.
Quoted from DirtFlipper:Tilt switches need to be open (and there should be four total; tilt bob, ball roll, under playfield, and one more somewhere).
Tilts= #1-plumb bob, #2- level ball roller,#3- under playfield, almost the top of playfield right side, towards bottom with playfield up, and number #4? I can only find 4 weighted leaf swithces, #3 in tilts, coin door, backbox just under score reels, and the one on bottom of cabinet. Lets eliminate bottom cabinet as a Tilt! and call backbox fourth tilt for now. your opinion on that? I will tell you why, bring us back to opening of this reply. I closed it "Bounce Switch", now for the first time I saw R pull in and hold. I knew I was in a game, so I touched some targets and watched scoreing reels move. Then I took a moment to really bend back bottom cabinet "Bounce Switch". Did a game reset, Lowerd playfield, added ball, and played 3 games!!!!VICTORY!!!!!!.
WOW, and I exhailed. I cant thank you enough! Walking me through the game this week , with your guidence, it made me appreciate you and pinside even more. Did I say Thank You!? Also shout outs to all that contributed and helped me in this thread. Dirtflipper was my moderator mentor and I really appreciate your time to respond to threads and requests for help. Thank You Thank You.
Have had, come and go, 20 some odd pins through the years. Here's some good Wickerman wisdom for all new EM owners.
Quoted from Wickerman2:You're going to need some of the basic EM skills or you'll end up creating other "symptoms" as you move around the machine checking this stuff out.
This is my first EM, Loved the art and backglass, played 10 games before purchase, and it felt good. Carefully got it home, put head back back on, all was fine till I moved it around a few times on pinball dolly. In looking over machine and looking for tilts, lord knows what i bumped, and opened that bounce switch. But though the week I learned some Em, learned this game inside out now. Learned much from pinside and internet, good way to jump all the way in on your first EM game.
A couple unanswered questions. Is the backbox weighted leaf switch the fourth tilt? Is "R" ok? It's the one thing I've had to touch the most in this event. Tilt relay arm or TB, still not sure if it's in it's home , or reset position? Have not tried a manual tilt yet, kinda don't want to. Weighted leaf switch count, I only find 4, is that right? Where can I buy a manual, best place to download one, seen a couple sights? Lastly, the R relay coil. It looks a little burnt, when I removed it I saw some char markes on housing wall, no others have that. I also can't fully read the burnt lable, the others I can read. This R coil, I think is A-9738#31? If so, the others are different on that bank.
Just went a played another before sending this. NICE!!!
