(Topic ID: 118940)
WPC-S Back Box GI Out-FIXED
By gjbwalker
9 years ago
#1 9 years ago
I'll preface this by saying I'm an electronics Noob . . . Need some help with my WCS backbox GI. Nothing works. The power driver board was just worked on by Clive @ CoinOp Cauldron.
Here is what I've done so far:
-Checked fuses (Pulled them out and checked). All good.
-Looked for broken wires. Couldn't see any.
-Folllowed Pinwiki to check continuity on J120 with Triacs etc. Good.
-Checked voltage J120 . . . see below
-Replaced the female connector at J120 and checked continuity from the connector to the last lights in the back box. Good.
The odd part is that I swapped J120 & J121 and the GI on the playfield worked at J120, but still the backbox GI did not on J121.
Also, when I checked the voltages for all 4 wires on J120 I got .245 or something like that, but when I swapped J120 & J121 and checked voltages I got 6 volts on J120.
I'm not sure where to go next with this. Any ideas?
Thanks in advance,
Greg
Post edited by gjbwalker: problem solved
#2 9 years ago
Quoted from gjbwalker:
How aboot the male connector? Are you sure you have continuity from the front of the board/pin to the back of the board traces?
If J120 works with both strings, and J121 works with neither, I might think it's not getting the correct juice to the pins.
EDIT: you have continuity with the female side to sockets, so let's look before that.
#3 9 years ago
I'll double check that and report back.
#4 9 years ago
You mention the playfield works on J120 and J121, correct, but the backbox works on neither?
You most likely have a wiring problem.
You may also not be measuring voltage correctly. GI is A/C, so instead of measuring voltage against ground, you measure voltage across 2 pins (supply and return) on the board.
Pins 1 & 7 - Brown String
Pins 2 & 8 - Orange String
Pins 3 & 9 - Yellow String
Pins 5 & 10 - Green String
Pins 6 & 11 - Violet String
#5 9 years ago
Law: I haven't had a chance to pull the board and check continuity through the board yet.
John: Correct on the J120/121. How I tested the GI was meter on AC and measured the solid color (I can't remember colors as I'm at work) like yellow on J120 with white/yellow on J120. There were only 4 wires on that connector, so I did the same with corresponding wire combos. Is that correct?
I think I have a picture on my phone, I'll try and post . . .
#6 9 years ago
#7 9 years ago
Unplug J120 and J121
Measure across all the pairs.
If the yellow pair and the green pair are still lower than the others, work your way back through the board. Check the continuity. Are the fuses good?
If all the continuity tests pass, and the voltage on those pairs are low, you've likely got a GI input problem. Transformer to secondary harness? J115?
#9 9 years ago
Just an observation but I might be wrong. It looks like the connector to J121 has a couple of wires on the IDC that do not appear to be in that great a shape. Meaning the wires do not appear to be plugged into the IDC very well.
#10 9 years ago
I'd replace that connector housing and connectors that are shown plugged into J121 in that picture. Get rid of that IDC and use crimp connectors.
#11 9 years ago
Quoted from schudel5:
Exactly. As per Clay's guide and many others. Connectors, Connectors, Connectors........
#12 9 years ago
Quoted from johnwartjr:
Just to be clear John, measure the voltage on the male pin pairs? Pin 3 & pin 9, etc . . . sorry noob here. If not please explain.
Fuses are good.
I'll ask about this after I check your first test.
Quoted from DareDevyl:
So far everything on J121 works as it should, but will probably replace it.
Quoted from german-pinball:
Mightbe, my grafic can help you:
Learning a lot here everyone . . . thank you!
#13 9 years ago
Fuses are good.
Yes, measure the pairs of pins against each other
Do both J120 and J121
One probe on pin 3, the other on pin 9, etc
Check all the pairs
#14 9 years ago
Well John I measured J120 and J119 before I pulled the board, but did not do J121. I can put it back in and test again?
Continuity is good through the board at J120/121 and the traces are good. However this is what I got for voltages:
J120:
1&3 7v
2&8 7v
3&9 2.8v
5&10 2.8v
6&11 3.9v
J119:
1&3 3.9v
#15 9 years ago
Open the game and lift the playfield. There's a square connector where the transformer connects to the GI input wires for the driver board. 9 pin square .093 connector. Are any of those wires burnt? The connector housing would be browned or blackened.
#16 9 years ago
Did I undertand it correct?
You changed the male headers J121 and J120??
Hope, you did not destroy a VIA, because there are traces on the bottom and top of the board.
I would check the continuity again as follows:
A.
J121 Pin 1 to middle pin of Triac Q18
J120 Pin 1 to middle pin of Triac Q18
Same for J121 Pin 2, 5, 6 and J120 Pin 2, 5, 6 and corresponding Triac
See my grafic, you can see all traces on the board.
B.
A.
J121 Pin 7 to fuseholder F110
J120 Pin 7 to fuseholder F110
Same for J121 Pin 8, 9, 10, 11 and J120 Pin 8. 9, 10, 11 and corresponding fuseholder
Post the results of you continuity-tests.
C.
But first check the 9-pin connector jahnwartjr mentioned in the post before.
D.
Please make a photo of J115 and post it here.
Cheers
Ingo
#17 9 years ago
It sounds to me like he had Clive @ Coin Op Cauldron repair his driver board. If so, I have nearly absolute confidence in Clive's work - that's why I'm suggesting the 9 pin connector.
#18 9 years ago
OOPS, sorry, I did not read this in post 1.
You are absolutly right, the 9-pin connector is often overseen, so that shoul be checked next.
Nethertheless my tip goes towards J115 (femal connector) and/or bad/loose/corroded fuse holders.
#19 9 years ago
Ingo, I checked everything you mentioned for continuity and everything was good.
Correct, John, Clive did work on this board and I've never had an issue with his work.
I checked the 9 pin connector and it looks decent. I had reseated it earlier and same result. Here are some pics... Some fuses look bad but I pulled them and they are good.
#20 9 years ago
J120:
1&3 7v
2&8 7v
3&9 2.8v4 and
5&10 2.8v
6&11 3.9v
J119:
1&3 3.9v
These measurments show, that there is someting wrong in the SUPPLY area and not the RETURN area of your GI circuit.
Your GI strings 3, 4 and 5 are not working.
So please measure BACKWARDS from J120/J121 towards the transformer, e.g. from J 120/121 9 to Fuse F108 right side (testpoint 1), then F108 left side (testpoint 2), then to J115 4 (testpoint 3)- same for the other faulty GI-strings.
Put you DMM to VAC, we measure the mentioned test points against ground.
Post the results, we will find the faults, the GI-circuit is pretty simple.
Cheers
Ingo
#21 9 years ago
20150221_111924.jpg 537 KB
20150221_112152.jpg 124 KB
20150221_112014.jpg 298 KB
Your J115 female connector, the black one, does not look good, I see there someting burned and/or corroded!!!! I am sure, there is the fault.
You say, some fuse look bad, but are good. BUT how do the fuse holders look like - is there corrosion?? Please clean them!!!
#22 9 years ago
Thanks Ingo. I'll get back to you with some numbers. Can I replace the J115 Female connector with the white molex variety?
#23 9 years ago
Yes, you can. And if possible and you have on hand, use trifurcon contacts!!!
Cheers
Ingo
#24 9 years ago
In the end I replaced the J115 female connector as Ingo suggested and that did the trick. Thanks Ingo!
And thanks to everyone else who helped!
Greg
PS You might see another help post as I have an issue with back VUK
#25 9 years ago
Great, you were sucessful .... and the iron rule is that you should always change BOTH, the header on the board AND the female connector
$ 259.99
Phoenix, AZ
5,975 (OBO)
Youngsville, NC
$ 49.99
$ 26.95
Pinball Pimp
Pinball Invasion
$ 29.99
Pinball Shark
Pinhead mods
$ 8.50
$ 329.99
$ 37.50
$ 63.95
$ 11.95
Slap Save Creations
Playfield - Plastics
Professor Pinball
$ 41.99
Lee's Parts
Plantsville, CT
$ 9.95
$ 17.50
Lafayette, LA
This page was printed from https://pinside.com/pinball/forum/topic/wpc-s-back-box-gi-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
