Bought a HUO very low play LOTR LE. Looked and played like NIB up until the left flipper failed while I was cradling the ball. Thought it was the known LOTR flipper coil issue, but after inspection, saw the coil fuse was blown.
When I replaced the fuse as listed (3A, 250V SB), immediately upon power-up (while game was still booting), the flipper fully actuated, held the up position for a second or two, and then gave out. New fuse had immediately blown before I could even press the start button.
Checked out the board, and sure enough, Q15 transistor failed the continuity test using multimeter. I'm going to remove the board, and I've got some quality time planned with a fellow pinhead who is adept in circuit board soldering to replace the transistor.
My question is: Do I need to peel back the troubleshooting onion one layer further to determine why the transistor went bad? (ie. EOS switch, etc.) Or have enough of you out there just simply had transistor failure issues with Stern's flipper transistors?
EOS switch seems to register appropriately in the Dedicated Switch test, but I don't know how to check if EOS needs adjusting beyond that. Any suggestions/instructions, or links to other threads that describe how to do this would be much appreciated. Thanks.
