I've only ever seen this on a WPC95 game. On that boardset there are a couple capacitors that get changed out.
Do you have any other DMDs you can swap in from another game? Or maybe a different WPC display driver board you could put in this HS2 to isolate the problem to either the display or the driver.
Make sure boards are screwed down to back. It's probably interference thus look for ground issues. Check the entire ground grid.
First, run display test as mschonbrun suggests, above.
Second, if you have another WPC game (not WPC-95), swap DMD controllers to see if the problem follows. You can't damage the game doing this.
If the problem follows the board, there are two filter caps on the board that are 150uf/160V. Replace them with the more common 220uf/160V caps. It's a pretty easy replacement if you have any skills at all...and a decent iron.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
Quoted from ChrisHibler:First, run display test as mschonbrun suggests, above.
Ok some questions arise from this
I have a fishtales can i swap the controller?
If the problems dont follow what should i do?
The DMD display isnt causing this?
Thank you guys
Quoted from Metzu:I have a fishtales can i swap the controller?
Yes.
Quoted from Metzu:If the problems dont follow what should i do?
Then the DMD is bad (unlikely causing this issue).
Quoted from Metzu:The DMD display isnt causing this?
That's a controller/HV board issue and not a DMD issue. You can swap the DMD driver board from HS2 into FT and I'll pretty much guarantee FT will have the issue.
Quoted from schudel5:Yes.
Quoted from PinballManiac40:I doubt reseating this ribbon cable will help but try it anyway. It is a source of many animation issues that are not voltage related.
thank you guys as always!
so if its a controller/HV board issue its the worst case scenario? what should i do then?
thank you guys!
As Chris says...95% its the 2 large axial caps on the HV dmd controller board. . Either way they are old and need to be replaced anyways.
Easy to swap out with a temp controlled solder iron.
Quoted from Hawk007:As Chris says...95% its the 2 large axial caps on the HV dmd controller board. . Either way they are old and need to be replaced anyways.
thank you!
thank you guys i whish i could spot them! i´ve been googleing for them caps!
Quoted from Metzu:thank you!
Not sure if you meant that you can't find them on the board or that you can't find them for sale. Anyways, here's the location for both.
https://www.greatplainselectronics.com/proddetail.asp?prod=CEA-220uF-160V-RMD
Quoted from schudel5:Not sure if you meant that you can't find them on the board or that you can't find them for sale. Anyways, here's the location for both.
Thats it thank you
This page was printed from https://pinside.com/pinball/forum/topic/rolling-lines-on-dmd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
