(Topic ID: 196356)
LOTR switch problems ...
By foxicp
6 years ago
  • 15 posts
  • 6 Pinsiders participating
  • Latest reply 6 years ago by KoP
#1 6 years ago
Hello pinside's community !
I think i have a problem on my lord of the ring pinball machine but i'm not sure ... when i play a game , all seems to be ok . no error on start.when i put my pinball machine on test mode , it says that all is ok BUT when i test switches with the switch test diagnosis , there's a lot of switches that register twice when i hold them : for example , when i push the switch number 9 , i hear a sound and on the dmd screen i can see the switch registering but when i release it it register again. like if i have pressed two times this switch.. I attached an image and i marked switches that have this problem.
any help would be appreciate!
thanks
PS:sorry for my bad english
#2 6 years ago
Does this happen when testing the switch with a ball, testing with your finger, or testing with something else?
If you disconnect the playfield and test the switch matrix using jumpers do you still get the error?
6 months later
#3 6 years ago
Hi , sorry for the delay.
I did what you told me .
it happens when i test the switch with a ball , finger...
it also happens when i disconnect the playfield and test the switch matrix using jumpers.
so i think it is not a switch / playfield problem...
#4 6 years ago
http://www.pinwiki.com/wiki/index.php?title=Sega/Stern_White_Star_Repair#Switch_problems
It looks like only your optical switches on the matrix are malfunctioning but I don't know what might cause that. Low voltage maybe?
cfh might be able to suggest something.
#5 6 years ago
it is not just optical switches because classical switches does the same.
if you look at the matrix that I posted earlier, we can see all the switches in color that have this problem.
another idea ?
#6 6 years ago
Power off and try reseating the connectors on the driver board.
#7 6 years ago
Hi all , i tried to reseat all connectors and it is the same problem .
can anyone who have a lotr can try with his pinball if it does the same or not ?
another pinsider have contacted PM me to see if i have a solution because he have the same problem with his lotr .
another idea ?
regards.
#8 6 years ago
I know i posted in this thread but i did not realize it was 7 months old!!!???
To the OP are you stating it worked before and now its having other issues??I'm lost
#9 6 years ago
I took a long time to fully restore the pinball, so that's why I put a little time to perform the tests.
Since I bought it, it has always had this problem. I do not think it's normal operation and knowing no one with the same pinball, I can not test if it does the same thing.
#10 6 years ago
I would post your question in regards to if that's normal in the LOTR club thread. Possible it's a board problem, but would be unlike any I have ever seen on the switch matrix.
https://pinside.com/pinball/forum/topic/the-lord-of-the-rings-journey-begins-members-club
#11 6 years ago
It's very possible that the previous owner or someone wired a switch/switches in the wrong order.The switch/switches that are registering multiple switches would be a good idea to look into and see if the wires are in correct order and test diodes(If any are there) with multimeter.
#12 6 years ago
Yeah I'm the guy who pm'd when I found your thread researching similar problems... I have every switch you indicated on mine also registering double in switch test, BUT my "mini PF U.L." (potd, top left switch) does as well and also registers/triggers the next switch on the row, the orthanc opto switch (top vuk). You don't have any oddities with that mini pf switch?
I asked about this in the club thread (on page 53 I think), and one guy seemed to indicate the same behaviour with his lotr there, including the "mini PF U.L." switch behaviour, however his did not exhibit the problem when disconnecting the switch connectors at the board and testing with jumpers as you say yours does. That kind of points in two completely different directions... To double check, you removed the switch/row column connectors on the board, and jumpered one pin at a time down the line on the board down those headers per this process? http://www.pinwiki.com/wiki/index.php?title=Sega/Stern_White_Star_Repair#General_Switch_Matrix_Testing
I guess I need to try that here on mine next, but I wondered if the problem may not just be with the Stern switch test itself - I have no problems in game play and from what I can tell none of the switches act up at all during actual play. I could not tell any switches were double registering when a game is started, and switches are manually triggered... I may just drop it until an actual problem is seen in gameplay though.
#13 6 years ago
Looking over the readme file for the software there have been many bug fixes throughout the different versions. Are you on version 10.00?
http://sternpinball.com/upload/game-code/game-code-the-lord-of-the-rings/lotr.zip
#14 6 years ago
Quoted from YeOldPinPlayer:
Honestly i ran the old version roms for a long while in my lotr and never had any problems like what is being stated
#15 6 years ago
Quoted from PinKopf:
That would have been me....
What I was trying to say was that the "mini pl ul switch triggering the orthanic opto" problem didn't occur when testing the board with jumpers. The other problem does.
The switches that are activated twice in switchtest are the trough, lock, vuk and saucer switches, the shooterlane switch and the stacking opto. Those are all switches that the ball activates for more than just a short moment. That almost can't be a coincidence and the game plays absolutely fine, so I think this behaviour is normal.
The mini pl ul switch behaviour occurs with just 1 row (CN7-P9) and 2 colums (CN5-P6, CN5-P7) connected to the board. I haven't looked into this any further. I noticed that in gameplay the game doesn't fire the orthanic vuk when the mini pl ul switched is activated.....
$ 200.00
Professor Pinball
€ 7.50
Pin-Decals
RGP Models
€ 7.50
YouBentMyWookie
RamMods
RamMods
$ 12.95
PinWorlds
$ 12.00
$ 19.95
Mitchell Lighting
11,000 (OBO)
St. Charles, MO
PinWorlds
9,000 (Firm)
Ronkonkoma, NY
9,500
Anderson, SC
$ 1.00
Pinball Alley
$ 41.00
$ 130.00
Dijohn
$ 29.00
Pinball Photos LLC
$ 5.00
Pinball Fuzz
10,400 (Firm)
Juneau, WI
PinWorlds
This page was printed from https://pinside.com/pinball/forum/topic/lotr-switch-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
