(Topic ID: 217498)
Iron Maiden issues
By rvdv
5 years ago
  • 2,495 posts
  • 364 Pinsiders participating
  • Latest reply 9 months ago by Skinner
  • Topic is favorited by 157 Pinsiders
11 key posts have been marked in this topic, showing the first 10 items.
Display key post list sorted by: Post date | Keypost summary | User name
Post #96 sarcophagus switch fix. Posted by DG_Amuse (5 years ago)
Post #434 Black t-moulding pictured to replace stock banana yellow. Posted by Strummy (5 years ago)
Post #597 Stern fix for Newton Ball issues on LE Posted by Fytr (5 years ago)
Post #887 Fix for fast balls not registering on upper loop Posted by PinNin (5 years ago)
Post #1039 Picture of factory fix for bad mummy newton ball on Prem/LE Posted by RA77 (5 years ago)
Post #1343 Fix for fast balls leaving wireforms Posted by Kevlar (5 years ago)
Post #1452 Shim method to get auto launch to work nearly 100% Posted by hank35 (5 years ago)
Post #1713 TECH: PLAYFIELD. Fix auto launch consistency with stronger coil Posted by NeilMcRae (5 years ago)
Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
There are 2,495 posts in this topic. You are on page 1 of 50.
#1 5 years ago
Just thought since I play this a lot coming across problems:
1) speakers on LE keep crackling , cutting out
Sound card replaced by Stern but nothing
Other fix ?
2) newton ball hits don’t register: adjust leaf switch and it’s fixed
3) game goes into ball search after ball ended but nothing happens
After 3 ball searches it finally ends the ball
Any tips ?
#2 5 years ago
3.) cold solder on trough opto board?
#3 5 years ago
Quoted from rvdv:
Other fix ?
Any tips ?
1. What is the volume at? What is the music attenuation at? Speech Attenuation level? Sounds like you're clipping the on-board amp.
2. Are you saying that it goes out of adjustment when you play it? And is it the hits with or without the captive ball?
3. Check the ball trough for all positions registering in switch test mode. Use "clear ball trough" in the diagnostics and watch the trough sensors on-screen as it cycles through balls.
#4 5 years ago
Quoted from rvdv:
Other fix ?
Any tips ?
Can't help on the first one, but I can on the third.
Stern's ball trough rollover switches can sometimes not register due to a sticky or stiff switch. Generally, a simple adjustment to the rollover leaf will allow the pressure of the ball to make more constant contact. This can show all the time, or more typically in a scenario where the ball slowly falls in the trough and doesn't have the inertia to activate the rollover. I would bet it is the last switch to the left in the trough. It is simple to get to. Worst case scenario, you could put in a new switch. Some of them just inherently have more resistance and require some adjustment. I had this same issue with my Walking Dead and it now functions just fine. Best of luck.
#5 5 years ago
Quoted from PinMonk:
1) sound is set at 35, no other adjustments made then factory. The speakers (sound) makes crackling sound the whole time
The louder you go the more noticeable it gets
2) issue is fixed on mine but hear it from others so just wanted to post problems and fix
3) thanks , will check the switches
In the menu all looks great
It only does it ones so often
#6 5 years ago
Quoted from rvdv:
That's pretty loud. If you want to rock out, I'd suggest using the line-level L/R output on the Spike2 board into an external mini-amplifier that can handle the sound at that level without breaking a sweat. You don't have to break the bank. One of the $30 ones like in Houdini would work fine.
Amazon has it here for $26.30:
https://www.amazon.com/Pyle-PFA300-90-Watt-Amplifier-Adapter/dp/B0071HZ5LE
#7 5 years ago
Your #2 issue is happening to me. This unusual switch mechanism is just poorly designed. It has to be very tightly gapped to work, if it is slightly too loose or slightly too tight, it doesn’t register. I have had to adjust mine several times. Even if you have it correctly gapped, with a second ball present, sometimes direct hits don’t register. You need to hit it with a glancing blow to consistently register hits. I suspect Stern will need to come up with a fix for this. Or perhaps someone in the community will come up with something.
#8 5 years ago
Quoted from SDTMinSTL:
I think the newest sterns use optos. At least my SW does.
#9 5 years ago
Well, game starts up normal without saying ball missing but with tech alert it says 1 ball missing
Next will open the playfield and look for missing ball ? Weird !!
EB7B0D8E-DB42-4510-89E7-F9975745456C (resized).jpegEB7B0D8E-DB42-4510-89E7-F9975745456C (resized).jpeg
18CBFCCC-B8E9-4DCA-A955-794C27BDFC30 (resized).jpeg18CBFCCC-B8E9-4DCA-A955-794C27BDFC30 (resized).jpeg
#10 5 years ago
In the first picture, it looks like you have a ball stuck on the plastic to the right of the center ramp. I’ve had balls stick there also.
#11 5 years ago
Quoted from rvdv:
If you clear the captive ball, does that take the alert away?
#12 5 years ago
Quoted from Russell:
Horribly designed switch. I think I have mine finally tweaked just right for now but man that thing is flaky
#13 5 years ago
amazon.com link »
This sounds like a great solution for you, RVDV. I mean, reading the Amazon description, this line alone makes it awesome and perfect for you:
"Party Machine
Create a karaoke session and let the fun begin. Use the mic and aux inputs to add life to the party."
ADD A CLIP ON MICROPHONE AND SING ALONG WITH YOUR IRON MAIDEN AS YOU PLAY!!
#14 5 years ago
Quoted from iceman44:
Hmm. Knowing what you LE owners know, what version would you recommend to those of us considering Pro or Premium?
#15 5 years ago
Quoted from IdahoRealtor:
Helped unbox a friend's LE and the sarcophagus mech was misadjusted out of the box. One of the switches wouldn't register, and it's nearly impossible to access. That whole mech concerns me, and the code couldn't compensate for any of the issues that came up with it.
#16 5 years ago
The initial plan for the route was get a Pro, then replace it with a Premium, but the LE/Prem playfield upgrades are underwhelming and the mechs seem fussy and not really "cool", so the Pro is staying and the Premium was cancelled.
If they had kept the varitarget and the lower scoop/subway, it would be a different story. Much more "cool factor" in a vari-target.
#17 5 years ago
Much more "cool factory" in a vari-target.
Yeah Vari would have been kick ass.
#18 5 years ago
Happens on every IMDN I've played sad enough.
#19 5 years ago
Quoted from GravitaR:
I see that too now that you pointed it out ....... sure does look like a stuck ball there
#20 5 years ago
Well that's just great. Never happened on mine, but now that I'm aware of it it's going to happen all the time...like losing a ball down the sewer drain!
#21 5 years ago
Honestly, I think the rational answer is a pro.
I like the extra features but I could live without them.
11
#22 5 years ago
Lots of complaints about the switch used for the Mummy captive ball.
I brought the bad design up first and got ridiculed by Chambahz and Flynn because it's 'a design used for poppers for 60 years' or whatever
Great, maybe they should only use them on the poppers then because they don't work well on this game
To top it off, my motorized ramp flap took a shit again after rebuilding it.
Now Stern has to send me an entirely new ramp assembly... Awesome. Fun game but super unreliable thus far. Every game I play I wonder what will go out of adjustment or just stop working.
-1
#23 5 years ago
I’ve had a ball get trapped behind Sarc a few times if it travels at a certain speed I think
Goes into ball search. Have to poke it out of there.
Good news is you have time to replace the glass and lockdown bar before you lose it!
#24 5 years ago
Quoted from kpg:
I assume the Mummy switch is similar to Orb switch?
Haven’t had an issue with that one yet
#25 5 years ago
Yeah, its the same one. I got it to work, but there are times it doesn't register. Not as bad as the ramp flap getting stuck in the open position though. Hopefully I can get that fixed quickly.
#26 5 years ago
Is the ball supposed to stop at the clear window before dropping into sarcophagus? I think it is. Mine is fine until, of course, the third ball drops. And misses. On a good game.
Guess I'll have to try again. Woe is me.
#27 5 years ago
What !!! Can't you call Stern and have them send out a tech and fix it.
23
#28 5 years ago
Quoted from timab2000:
#29 5 years ago
At the moment it's possible to buy 2 pro's for the same price as an LE!!
#30 5 years ago
Got a total mystery on my hands
6 balls went in the game
Only 5 left ?
Nothing on top of the playfield or under??
0749F1D8-693D-4F03-868A-3C2BE3B49A94 (resized).jpeg0749F1D8-693D-4F03-868A-3C2BE3B49A94 (resized).jpeg
#31 5 years ago
Quoted from rvdv:
Only 5 left ?
So it's not on the right plastic like 10 people have been saying?
#32 5 years ago
Quoted from TheLaw:
That looks like the spotlight hood to me.
#33 5 years ago
Quoted from rvdv:
Only 5 left ?
Check:
Under the ramp?
Behind the backboard (stuck in wiring)?
Between the left ramp exit and the sarcophagus entry?
Behind the rubber inside the slingshots?
#34 5 years ago
Quoted from rvdv:
Only 5 left ?
I'm willing to bet it's in the sarcophagus mech.
#35 5 years ago
I was thinking that too, but then I saw what I think they are talking about:
EDITED: My guess was wrong....and I now see what I was looking at was the opto on the outside of the ramp.
11
#36 5 years ago
Quoted from rvdv:
Only 5 left ?
Are you sure you don't have Houdini??
#37 5 years ago
Quoted from kpg:
I already suggested that in post 11. The fact that it's still lost seems to indicate it's not stuck there.
#38 5 years ago
Quoted from kpg:
You are the winner !!
056E485D-9672-4CFF-8294-FC26963A5218 (resized).jpeg056E485D-9672-4CFF-8294-FC26963A5218 (resized).jpeg
#39 5 years ago
Quoted from rvdv:
Haha. Could have saved 26 posts by checking it earlier!
So, likely the switch in there is not registering properly so it doesn't know the ball is in there.
#40 5 years ago
In ball search this ball does not kick out
With the eye you can’t see it
So if you missing a ball shoot/roll another ball in there and hope both come out
If not go to coil test and keep opening it till ball rolls ou
#41 5 years ago
Quoted from rvdv:
Come on man!
#42 5 years ago
Quoted from rvdv:
But if the switch in there is registering, it will know where the ball is and not report it as missing.
#43 5 years ago
The winner gets to wash my car
#44 5 years ago
Wasn’t visible there in the initial pics...? Glad you tracked it down.
#45 5 years ago
Had the same issue with my AC DC Vault Premium. Replaced two of the stiff switches after trying to adjust them. The stiffness just caused the blade to bend more, each time I adjusted it. Ordered 6 new switches and chose the softest two. No more problems
#46 5 years ago
Quoted from rvdv:
LOLLL
Glad you found it !!!
#47 5 years ago
Sometimes my game seems to lose count of the number of balls. Typically, it will be in Mummy MB, when the second-to-last ball drains, it kills the flipper and counts bonus. I need to pay closer attention to the precise scenario when this happens, but has anyone else experienced this?
#48 5 years ago
Actually I’ll change my opinion
I would want all of the features of this pin it’s that good
It’s addictive like TWD. Maybe more so
Get the premium
#49 5 years ago
So....what is the fix on the crackling sound ? My pro does that along with my AS pro. My GB prem does that at high volumes as well , what gives man ? Does Stern build there games that they cant handle their own power at high volumes and causes the amp to get overloaded and start clipping on and off ?
#50 5 years ago
Get the premium
I'm not sure your first opinion isn't correct as the Premium doesn't pencil out $$ wise for the added features and it has the least appealing artwork, imo. That being said, if I liked the art I'd still buy a Premium because this game is so cool.
$ 29.99
Cento Creations
$ 27.99
Lee's Parts
$ 50.00
Duke Pinball
$ 50.00
Duke Pinball
$ 25.99
Lee's Parts
$ 27.95
SilverBall Designs
$ 5.00
Pinball Fuzz
Filament Printing
$ 8.00
Pinball Fuzz
$ 50.00
arcade-cabinets.com
Pinball Pro
$ 55.00
Tucson Pinball
$ 12.50
5,850
Matthews, NC
$ 1,059.00
$ 22.50
arcade-cabinets.com
arcade-cabinets.com
6,000
Warner Robins, GA
$ 22.95
SilverBall Designs
$ 50.00
arcade-cabinets.com
$ 100.00
Duke Pinball
This page was printed from https://pinside.com/pinball/forum/topic/iron-maiden-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
