(Topic ID: 213561)
IO board fault analysis
By shaneo
6 years ago
    #1 6 years ago
    4/4 IO boards in my FullT have faulted with Q20/coil 6 gnd shorts. This evening Q20 replaced on 2x I/O's and tested all 4 I/O locations. Both developed same fault when connected to big board on LHS.
    Big LHS brd removed. Tests with short col 1 gnd - col 2 70V at connector.
    No wonder I/O's are failing.
    I/O's have A,B,C pins on column connected.
    No solder bridges found but trace existed in PCB col 1 col 2. Trace cut, mosfets
    replaced ,re-tested, no faults found.
    Fair dinkum, I can knock up boards like this in my toaster oven.
    #2 6 years ago
    #3 6 years ago
    Apprently The same issues are occuring in Alien pins.
    #4 6 years ago
    I've had my Alien less than a week and it's started blowing fuses. Seems to be the AC side of the 70V supply (next to Br.Rec). The 6.3A fuse goes after a few flips so I'm wondering if this is a similar issue? Helmut suggested I try swapping I/O boards around. Should I be looking for bad traces around the mosfets or checking for shorts?
    This page was printed from https://pinside.com/pinball/forum/topic/io-board-fault-analisis and we tried optimising it for printing. Some page elements may have been deliberately hidden.
