(Topic ID: 214708)
Gottlieb Fipper Chatter
By mrbanjo
6 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by mrbanjo
#1 6 years ago
What is the main cause of flipper chatter? Not seating against the coil stop?
The EOS looks right
#2 6 years ago
Broken hold winding would do that.
The flipper chatter as you call it, is a sign that your eos works correctly.
Replace the coil or look for a broken wire at the connections of the thin copper wires.
Sometimes you can find it and re-attach it to the lugs.
Peter
www.inkochnito.nl
#3 6 years ago
Inkochnito is probably right but you can try swapping coils to make sure.
#4 6 years ago
A couple of things- the wrong type coil stop is installed, dirty and/or misadjusted eos switches. There should be a 1/8 inch gap at the eos switch contacts at the end of flipper travel.
#5 6 years ago
EOS switches not properly gapped..........have new coils in it and was doing it..............Thx !!!!!!
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-fipper-chatter and we tried optimising it for printing. Some page elements may have been deliberately hidden.
