Cryo claw is acting up on my demolition man.
Claw cycles 8 times at power on instead of 1 time like it should. Claw is not working in game and the diverter to guide the ball to the claw never actuates. Every once in a while when I turn it on it the claw only cycles once and the diverter works and the claw magnet will pick up the ball but will not move.
Test reports a magnet broken fault
Claw test mode results:
Left and right claw works in test mode and opto switches show switches reading, switches also work in switch test mode.
Magnet works in test mode.
Elevator hold switch (74) shows closed in test mode and shows open when the opto is blocked.
Elevator index switch (67) shows closed in test and does not change state when cycling the elevator in test mode.
This tells me opto 67 is not working, I pulled the elevator cleaned the opto and reflowed everything and no change.
I checked the connections at j1 and j2 on the 7-opto board and all looked good.
My question is how do I tell if the problem is with the opto 67 board or if the 7-opto board is the problem?
Is there anything else I should be looking at?
