(Topic ID: 217856)
Are WMS and Gottlieb transformers interchangeable?
By Mikala
5 years ago
  • 11 posts
  • 7 Pinsiders participating
  • Latest reply 5 years ago by HowardR
#1 5 years ago
I discovered today that a Target Alpha I picked up a long time ago does not have transformer. I have a spare transformer that came out of a Williams Triple Strike. Will this work with the Target Alpha? The TA is my first jump into restoring a Gottlieb.
#2 5 years ago
I doubt it.
#3 5 years ago
Quoted from Mikala:
I discovered today that a Target Alpha I picked up a long time ago does not have power supply. I have a spare power supply that came out of a Williams Triple Strike. Will this work with the Target Alpha? The TA is my first jump into restoring a Gottlieb.
Heresy! haha. If you're talking about the transformer, then yes it should work. Both take 110v in and deliver 24 or 25v, and 6v out.
RTS : ) Learn To Google? Read The Schematic!
#4 5 years ago
Voltage is a bit lower on Williams then on a Gottlieb (24 V) you can increase by using the high tap on a Williams transformer.
Don't know if it will be enough, but it will work.
#5 5 years ago
Do you have the TA schematic? Could you post picture of the transformer wiring in it to compare? As noted they put out similar voltages so it might be possible, but need to see if the commons, etc are wired the same.
Quoted from wizardblom:
Don't if it will be enough, but it will work.
What's the non-24v?
#6 5 years ago
Would be simpler to install a Gottlieb transformer. But that would require acquiring one.
#7 5 years ago
Quoted from zacaj:
What's the non-24v?
#8 5 years ago
Quoted from HowardR:
Learn To Google?
My LTG : ) doesn't mean that.
#9 5 years ago
Quoted from LTG:
That was funny
-Mike
#10 5 years ago
Thanks all for the replies and answer. I will just buy a Gottlieb transformer to avoid problems. I thought I could save a little money on this one.
#11 5 years ago
The Williams transformer will work with no problems
$ 12.00
965
Chesapeake, VA
$ 3.00
Space Coast Pinball
$ 24.98
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/are-wms-and-gottlieb-power-supplies-interchangeable and we tried optimising it for printing. Some page elements may have been deliberately hidden.
