(Topic ID: 217958)
Best ACDC Speaker upgrade?
By Rick_H
5 years ago
  • 25 posts
  • 11 Pinsiders participating
  • Latest reply 5 years ago by Rdoyle1978
#1 5 years ago
First time posting, first time pin owner! I just purchased the AC/DC Premium which will be getting delivered next month. I have done my research and read a lot of topics here about speaker upgrades, most of them being several years old. Anyway, here's my question...what speaker upgrade has worked out the best and sounds the best? It seems like the choices are between the setup from either PinballPro, or the one from Flipper Fidelity. I am also very interested in the setup from Markmon in which he installed an amp, with a possible upgrade of the sub and the backbox speakers.
I am not looking to shake my house or hear it down the street, I am just looking for something that will make the music sound great!
I appreciate any input!!
#2 5 years ago
External sub is all I have, sounds great. Polk psw10
#3 5 years ago
Quoted from Lermods:
This is a must. I also add Flipper Fidelity upgraded speakers to my pins.
Nothing better than AC/DC Rockin the house.
#4 5 years ago
same here. external subs on most pins. polk psw10. wait for it to be on sale on amazon or newegg.com. can hook two pins on one sub. much easier to install too.
#5 5 years ago
Ok, I guess I should have added the external sub to my original post. So far three thumbs up for external subs!!! I did read some reviews of external subs, but it seemed that people overall preferred a better sub in the cabinet. I will try and find a post that explains how to wire it up. I am guessing that I just need to extend the existing wires from the cabinet sub and wire to left and right channel on external sub? Or do both wires go into the same channel on the external sub since it's not playing in stereo?
#6 5 years ago
Quoted from Rick_H:
For AC/DC I'd go with external sub. I have the Flipper Fidelity kit on mine and am actually pretty disappointed with it on this title. The external sub was the overall better move I made on the game.
You have two main options:
- Alligator clip method. You soldier (or crimp) some alligator clips to the end of some speaker wire. Connect the positive side wire to the positive terminal on the powered external sub and the neg to the neg. This is what I've done and was a great use of the alligator clips that come with the comet matrix light kits, just a FYI
- Buy the sound board add on. I haven't used it before but I've been told that it creates a cleaner and more powerful sound. I believe the board runs about $35. It connects to your stock board and adds pre-amp outputs. http://www.pinnovators.com/catalog/product_info.php?products_id=38
One thing to add. I also like to get the volume control button that goes in the tournament button location. Makes turning the sound up and down a breeze mid game as necessary. https://www.pinballlife.com/index.php?p=product&id=2894
#7 5 years ago
Quoted from 85vett:
You’ll overall get a better result with an external, enclosed, powered sub (ie anything you can plug directly into your stereo).
Cabinets just don’t seem to be well-suited for good bass, and none of the fancy pinball upgrade kits are using enclosed woofers (aka a sub) which you must have in order to get good punchy bass. Plus, the games’ amps don’t really provide enough power so you have to upgrade that too.
I asked Greg from PinballPro about it, and he said they didn’t have anything in that vein, but my impression was that they had not really like they had looked into it much. It’s more expensive, for sure, so it’s probably not a great business strategy for them.
Bottom line: an external sub has its own amp and enclosure and is far and away your best option
#8 5 years ago
Fully agree from a bass perspective. I got the FF kit in goals of getting better mid and high sounds from the backbox speakers to go with the better bass from the external sub. Didn't notice near the improvement with AC/DC that I did with my AV and TF. I'm guessing it has to do with the compression of the songs but I'm not sure.
#9 5 years ago
This is a no brainer...dont wast your money on the flipper fidelity speakers...buy the pinnovators sub board ($35), and an external sub ($100)...both can be purchased for less than the speaker upgrade and they improve the sound immensely ..... I have the stock speakers in my ACDC Prem with pinnovators and external sub and it sounds better than the Met with flipper fidelity speaker upgrade....
#10 5 years ago
Ok, external sub it is, with the pinnovators sub board and probably the PinPac as well. Backbox speakers...I plan to change these out either way with a much better quality 4" speaker. Should I just plug and play, add an amp...recommendations?
#11 5 years ago
Quoted from Rick_H:
Make sure to get the right OHM speakers otherwise say goodby to your sound board. It's not as easy as just taking some off the shelf auto speakers and slapping them in the game. Have people done it - Yes. is it safe and something I would recommend - Nope.
#12 5 years ago
Quoted from Rick_H:
You won't hear much of an improvement with new back box speakers because of the quality of the audio coming out of the game. It's not necessarily a speaker issue, but a compression issue I believe. If there was a way to tweak the audio with an equalizer, that might work, but i don't think this is possible.
#13 5 years ago
Quoted from Rick_H:
I recommend the Pinnovators PinPAC headphone kit (including the separate sub connection module). I have installed these along with a Polk subwoofer on all my modern Sterns and it's so nice to have the ability to easily change the volume during a game as well as have the ability to plug a set of headphones in when needed!
Another advantage of the PinPAC unit is that they enable you to easily turn the external volume on/off too. I routinely turn the sound off on all of my games before shutting them down so that the otherwise occurring speaker pop is avoided when the game's power is turned on or off.
#14 5 years ago
Quoted from Tuna_Delight:
Thanks Tuna, I was wondering if the PinPAC only adjusted the headphone volume, or the overall speaker volume. Definite purchase then!!! Sounds like I am set. From what I have been reading, there are mixed recommendations on changing out the backbox speakers. Maybe I will see how the stock speakers sound first and maybe change those out later with some 4" Polk speakers. Some say it doesn't make a difference, some say the highs and mids sound better.
#15 5 years ago
If you want the best, it will cost you:
#16 5 years ago
Quoted from Rick_H:
Quoted from 85vett:
It's pretty straight forward and safe if you're not reckless about it. Get some coaxial car speakers which are 4-ohm (many use the Pyle blues) and wire them in series: don't just drop them in, the existing wiring is parallel with 8-ohm speakers.
#17 5 years ago
I have seen a few people comment about the music quality/possible compression issue from the format of the songs being played. Has anyone found a fix for this, or it is what it is?
#18 5 years ago
Quoted from Rick_H:
There is no way to improve the compression of the source audio. It's compressed before it's even loaded into the software. The output you get can't be uncompressed.
#19 5 years ago
Does AC/DC support the pinBrowser? That's a way you could get better fidelity audio
#20 5 years ago
Quoted from Rdoyle1978:
Yes, it does support pinball browser and that is a good thought about doing so. Not sure how it will be effected by the memory though as I believe the board is just about maxed out and also one of the reasons the songs are compressed the way they are.
They aren't bad but just doesn't seem to get any better with better quality speakers like some other games do. My MET is about the same way. MET felt better than AC/DC though but not by much. Nothing like my other SAM based games. For instance TF and AV made a pretty significant difference.
#21 5 years ago
Quoted from 85vett:
if the board is maxed out, that is more about disk space/memory; the compression that's being discussed is both data compression and audio compression (too much of either can lead to lesser quality), so there might be a way to find a better happy medium. less audio compression is best (the audio is already compressed the way the band wanted it to sound). MP3 format does both - smaller file size but you also lose a lot of fidelity. it tosses out sounds you can't hear (too high or low frequencies, or sounds which are layered on top of one another - the bottom layer gets discarded). Anyway, there should be a way to re-do those files. Pinball companies are not known for their mastery of the audio parts of the game
#22 5 years ago
Guess you could try taking the tracks off a CD and use a tool like audacity to filter/compress it and then upload it via pinball browser. Would be interesting to see/hear the results.
#23 5 years ago
I think it's a stretch to think that professionals doing pinball programming or sound packages could be easily improved upon by your typical Pinball Browser user. There are alternative packages out for Walking Dead that are very well done though, maybe one of those creators would have some insight about improving the quality of the source material.
#24 5 years ago
Quoted from YeOldPinPlayer:
Hey now, don't burst our bubble and let us feel smart for a min...
P.S. - Don't you have some spreadsheet to update. I want to know who won last night (Better have been you since you knocked me out)
#25 5 years ago
I was really just referring to the notorious Bally/Williams speaker configuration
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 29.95
$ 12.95
$ 110.00
16,500 (Firm)
$ 160.00
Sparky Pinball
12,999 (OBO)
Richfield, MI
Game Room Info Shop
Filament Printing
$ 54.99
10,300 (Firm)
Downers Grove, IL
$ 17.50
$ 11.95
$ 24.95
$ 100.00
Duke Pinball
$ 29.95
$ 159.00
Sparky Pinball
YouBentMyWookie
12,000
Ontario, CA
€ 99.00
Watssapen shop
$ 29.95
$ 11.95
Hookedonpinball.com
$ 99.99
$ 50.00
AC/DC Glass Cover Pre-order!
Duke Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/acdc-speaker-upgrade-2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
