Quoted from markmon:Zen is an app. It doesn't have the ability to blue screen your computer. That can only be done in kernel/driver area. Apps doing bad things can only get killed or crash but not take down the system with a blue screen. That indicates a hardware or driver problem. Most likely in your video card. What was the blue screen error codes? They're given to help determine the cause.
Flipper lag is a combination of your LCD display and the video cards stock pre rendered frames setting. There are instructions on ATI and Nvidia cards. But in Nvidia, its called max pre rendered frames. It defaults to 3, you need it to be 1.
I have the Intel onbaord gfx from their newer boards we put in
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff960002fc46e, 0xfffff88006da2cc0, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 112113-54647-01.
Seems like gfx driver error. I'll poke around with updates
