Hello,
I'm having a problem with a Zaccaria Time Machine. This machine has been talked about before here in a [previous post](https://pinside.com/pinball/forum/topic/zaccaria-time-machine-rising-playfield-problem#post-2492313). When I got it everything was working well.
Now the problem seems to be that the machine seems to mostly think it is in the past. Every time the ball lands in the time hole. The pop bumper platform raises or lowers as expected, but the machine almost always announces "now you will go into the past." In this state, the drop targets only award a bonus in the past. The worst side effect of this is when playing with multiple players. Then, the pop bumper platform changes position on the next ball (e.g., Player 1 gets the platform up, then drains; the platform goes down for Player 2). Needless to say, the machine "as is" can't be used in a tournament.
I have gone through all switches and they all check out. Switch 51 (the switch that marks if the platform is down or not) seems good too. The connectors for the switch matrix were weak and old, so I have changed all of them with trifurcon pins. That didn't seemed to make a difference, but on the other hand all the switches still work.
From reading online, I thought that IC38 might have been bad (since "maybe" the future/past state was part of the matrix?). I socketed and switched this as well and it didn't seem to make a difference. I also thought that maybe some transistors were bad, but they all seemed OK as well.
I'm starting to get at wits end here. I'm hoping someone may have seen this issue before or maybe has a suggestion. To me it seems like there is a problem in the software somewhere and not in the electronics. I'd be happy for any suggestions.
Thank you in advance!
