I'm doing a run of Zaccaria Robot rescreenings. IF you want to get in now it's going to be $200 less than normal, because i'm already going to be doing a screening run. Zaccaria cabinet cannot be stenciled, so the only way to get the original look and still be printed on the cabinet, is to silk screen it. Years ago I had screens made just for Zaccaria robot due to the crappy condition all the cabinets are in. Due to the silver base that was used from the factory.
Price is determined by how much prep you do yourself before i get the cabinet. Since i'm restoring my cabinet right now, it's easier to silk screen multiple machines at once, than it is to do one at a time. Since it takes hours to get ready for screening and cleaning up each screen after the actual screening process. So if you want your Zaccaria robot cabinet redone. Now is the time. Both inks I have are close to a spot on match to the original and have the semi translucency to them as well.
These are normal prices I charge for doing a rescreen, so at this time you get a $200 discount off of these prices.
so, if I get your cabinet fully stripped (side rails off, coin door out, lock bar reciever off, flipper buttons and shooter rod out, legs off, neck grill off, hinges gone, glass tracks out. all body filler done already, And you have the base Silver coat you want done, it's $800 ($600 now)
If you have cabinet completely stripped, and body filler done, but the silver base coat needs to be done and cleared. it's $1000 ($800 now)
if the cabinet has everything on it, and everything needs to be removed by me, and all the body filler work has to be done. It's $1400 ($1200 now)
If you need new siderails installed, the cost of siderails will be added to it. Pinball life sells the siderails for zacs.
If you want your game done. contact me right away so I have time to know what's coming before I start the screening process.
