It appears that the Sanctum drop target on this Shadow I'm working on might be in need of some viagra.
Issue:
- The wall does not stay up when the up coil is tested in coil test mode. When I manually push the wall up, it locks in place just fine. It then goes down without issue in coil test mode.
- Errors thrown on boot: Check switch 51, Wall Target Down, Err. Wall Target Bad Chk. Switch/Coil
What I've tried thus far:
- Removed assembly, fully cleaned all gunk from the wall plastic and everywhere else, making sure I reinstalled the E-clip and plastic bracket properly
- Verified that the switch is NOT engaged when the wall is up and engages just as the wall is nearly into full "down" position
- Confirmed that the linkage which pushes the wall up does not get caught on the switch arm.
- Adjusted the switch arm and tested it manually in edge test mode to verify it goes on and off as it should
Any/all advice here would be greatly appreciated! I've read dozens of forum posts already about this and I feel like I've tested all of the usual suspects but I'm sure I'm missing something here. Hopefully something simple.
Thanks in advance!
