(Topic ID: 155964)
Yet another gameroom build thread
By amkoepfer
  • 604 posts
  • 72 Pinsiders participating
  • Latest reply 2 years ago by MustangPaul
  • Topic is favorited by 37 Pinsiders
    There have been 210 images uploaded to this topic. (View topic image gallery).
    There are 603 posts in this topic. You are on page 1 of 13.
    14
    #1 4 years ago
    I decided to stop muddying up the gameroom pics thread and just start my from scratch build thread. I started the build a few months ago shortly after moving in, and its taking awhile since i only work on it a few hours a week. It will be around 1700 sq foot of finished space with a smallish work room and a closet for the wifes holiday decor. I had to gut all the old electrical and start over. It now has around 60 recessed lights (sounds like a lot, and it is, but they are on dimmers). There will be around 80-85 outlets as well on 5 20a circuits. Im sure ill be asking plenty of questions while i finish this build. After 3 months im finally doing some drywall and have 1 wall up. Pics to fillow
    #2 4 years ago
    These are the before pics
    #3 4 years ago
    The games in need of a home
    #4 4 years ago
    First room and bar framed out
    #5 4 years ago
    Demo pile from the previous owners workshop
    #6 4 years ago
    This will be my em room and music room
    #7 4 years ago
    Games are sealed up until the dust is done
    #8 4 years ago
    Temp kitchen area setup. Only building it to house the beer fridge. Door on the right is for the bathroom, unpictured door on the left is garage access. Stairs to the upstairs is next to the bathroom door
    #9 4 years ago
    Nevermind, i guess garage door is pictured
    #10 4 years ago
    10
    #11 4 years ago
    Extra dryer flex duct equals robot kid
    #12 4 years ago
    Finally some drywall up! Now im caught up with pics, ill post more as i do the work. Any thoughts or ideas on how to make it better are appreciated!
    #13 4 years ago
    looks great so far
    #14 4 years ago
    Don't forget to wire in some switches for the game outlets. And consider a built in surge suppressor at the panel.
    #15 4 years ago
    Great idea. I was going to put surge in at the outlet but at the box would be better. Switches for games may be difficult for moving games around and rearranging, but at least a few key outlets will always be used so that will work in a few spots. Thanks for the tip!!!
    #16 4 years ago
    You could wire some split receptacles where only one of the outlets is switched, the other always hot.
    Split is the third option shown here:
    http://www.do-it-yourself-help.com/outlet-switch-electrical-diagrams.html
    #17 4 years ago
    Thatd be convenient. Itd be kind of cool to do something odd to turn on the power. I know ive seen someone with a frankenstein like switch to turn on the games
    #18 4 years ago
    Looks great so far. I didn't have the patience to do mine so I worked a bit of overtime to pay someone to do it. Keep at and it will be awesome when done.
    10
    #19 4 years ago
    I wish i would have paid someone to do it. I considered hiring drywallers, but when you do the framing mostly drunk, 16 on center kind of turns into 16 here, 18 there, etc. Id be embarrassed to bring someone in now! So im stuck with drinking more and doing the drywall
    #20 4 years ago
    I made that mistake. Thought I'd frame and hand off the drywall. Well my frame job made my drywall expense increase so I didn't save anything.
    That room is big! Have fun filling it up. Only suggestion would be to make the EM room larger.
    #21 4 years ago
    Haha i will have fun filling it! I left myself plenty of room to grow! I dont even own an em game right now. I do have a 14 foot skeeball to go along one wall, i figure i can fit 7 or 8 comfortably in there, and maybe 40 in the main room if i pack them in pretty tight. Em room will also have a drum stage built just because i have extra wood, about 6 inch high. I dont even own drums! I have a set but they are my cousins. Ill have half stacks, pa system, lighting rig all set up as well. For music i have 12 in wall speakers throughout the basement on a selector so i dont blast music under bedrooms when fam is sleeping
    #22 4 years ago
    Quoted from amkoepfer:
    #23 4 years ago
    Hahaha, i wonder if a knocker would trigger it
    #24 4 years ago
    Presqueisle, i just looked at your gameroom pic, very nice! What did you do for your floor?
    #25 4 years ago
    Looks nice, big job. I tried to find someone to do drywall and the prices were outrageous so I did it myself. I just expanded my basement a bit, finishing off a 12x12 space. Took me about 4 days. Only used one 20 amp circuit for that room, my main box and sub panel are completely full now. Took down a wall i previously had put up. The expansion came at the expense of some workshop/woodworking space...amazing how priorities change. Look in the mirror on the far wall and you can see more pins...up to 9 right now and now I can add two more...funhouse anyone??
    #26 4 years ago
    Nice! I may hire someone to finish the drywall, or at least texture it, but i hope my room turns out that nice!!
    #27 4 years ago
    I see you are going with a drywall ceiling...it looks nicer, but man that's tough work. Mudding and sanding overhead is about as bad as it gets. I went with a drop ceiling, mainly because if you get a leak or want to run more wire, it's relatively simple to address.
    #28 4 years ago
    I went back and forth with it, but i chose drywall to make it look more like a room than a basement. My excuse for the access is...how often do i actually need to get to the pipes and how often do they break. I will be putting in access panels (fake vents) for gas valves and other necessary things. Im not looking forward to mudding and taping it! Im sure itll be horrible
    #29 4 years ago
    Consider putting in some pvc pipe in the ceiling with some access in case you want to run more wire down the road.
    #30 4 years ago
    I dont think i should ever need to run more wire, outlets every 3 to 4 feet, thick enough guage wire, plenty of lights, and enough speakers to have a rock concert, wired for tv in wall wire system in 2 locations, but i see what you mean, you never know!
    #31 4 years ago
    I ran 4 sets of CAT 6 cable from my gateway to every possible TV location in the house. Every device you buy is web enabled these days and I only wanted 1 switch on the network for maximum speed.
    #32 4 years ago
    Good point. Thanks for the tip!
    #33 4 years ago
    Looks awesome! So much space! Super jealous!
    #34 4 years ago
    Thanks! Ya its a pretty big area. Im hoping to get a lot of work done this weekend, except for saturday when i go to the ohio pinball show!
    #35 4 years ago
    Saw this from my old game room. He was pretty mad i inturrupted his game for a picture! He and i both cant wait till i finish this so we can go back to playing
    #36 4 years ago
    I would definitely have a professional do the drywall finishing and texturing if you have never done it before.I used to work in construction and did everything else including the painting.It's an art to do it well.Money well spent and not that expensive.
    #37 4 years ago
    Post a CL add for some cheap drywall finishers. I'll never mud/tape again....
    #38 4 years ago
    I would for sure hire someone to finish the drywall ......i see so many people try this themselves and get frustrated and hire someone ....and could of cost less then what it will after they have spent 2 weeks working on it.
    And FYI ....if not to far ahead i would glue the drywall on to walls with Dsa/20, Liquid nails or pl200 and just put 2 screws in the field of ceilings is all you need.
    Will be less work for you or taper and less room for error especially if you are doing painted ceilings
    #39 4 years ago
    Quoted from Stretch7:
    Very good idea. I have a friend that does construction and hes been helping me, he wants to do the tape and mud ourselves, and me hire someone to texture. Hes pretty unreliable though so if he doesnt come through when im ready ill hire someone!
    #40 4 years ago
    It's a Polyaspartic / metal epoxy concrete finish. Google some images! I really like it.
    #41 4 years ago
    Looks really nice. Im pretty sold on carpet for some reason, but i may have to reconsider!
    #42 4 years ago
    I just had a smaller basement room (concrete floor and walls) that I needed to have 'POP'. Yours won't need that I think.
    #43 4 years ago
    No it wont, but it looks good!
    #44 4 years ago
    Spraying texture is so easy a caveman can do it.
    Just get a 60 dollar hopper gun to attach to an air compressor.
    #45 4 years ago
    I hear its easy, but since ive never done it i dont want to screw it up.
    #46 4 years ago
    Just practice on some bigger drywall scraps to get the gun dialed in.
    What type of texture do you want? I like the spatter coat style, just like knockdown but you don't scrape with the shield, if you spray the spatter style really light it's orange peel, that looks great too...
    #47 4 years ago
    I've had people tell me they could do their own texturing but when I saw it in person,Holy Shit!
    #48 4 years ago
    Splatter is what im going for i think, like orange peel like you said. Im sure ill have plenty of scrap laying around, maybe ill give it a try. I know people that have the equipment
    #49 4 years ago
    I also like to buy premixed 5 gallons of texture spray from any real paint store....best of luck!
    #50 4 years ago
    Splatter is not as easy as one would think especially a true orangepeel but it easier then knockdown.... a regular small compressor will not do the the job properly ...it wont keep up...you will starting and stopping and will be very hard to keep it even. Pay the $40 or so dollars(whatever it costs down there) and rent a texture machine.
    Mixture and gun setting and even spray is the key to what kind of texture you want? But dont forget another important step.....use the right primer/sealer....up here we use Synko Quickdry is the main industry product but others will use Hamilton
    Im not a fan of the texture at all but easiest to to do for a beginner or DIY is sno-tex(popcorn as some call it)....something to think about
    $ 11.95
    $ 48.00
    $ 19.99
    $ 0.10
    Pinball Stuff
    $ 12.00
    $ 33.50
    $ 275.00
    $ 11.95
    $ 48.00
    $ 36.99
    Lee's Parts
    $ 58.00
    $ 89.99
    $ 115.00
    Cabinet Parts
    Merf's Pins
    $ 9.95
    Apparel - Unisex
    Pinball Wheezer
    $ 36.00
    Ramp-O-Matic
    $ 15.95
    $ 7,599.00
    Great American Pinball
    $ 999.00
    $ 74.00
    Id Rather Play Pinball
    $ 24.00
    Pin Monk
    $ 7,599.00
    Operation Pinball
