(Topic ID: 221453)
Yet Another Funhouse Restoration (finished!)
By uncivil_engineer
5 years ago
There are 62 posts in this topic. You are on page 2 of 2.
#51 5 years ago
Quoted from uncivil_engineer:
So with the holiday madness now over, Rudy is back into my shop.
I have now decided to turn my attention to the sound system in the game. I have never liked the speaker system used in the pre-DCS games, so I have decided to do a speaker upgrade in my Funhouse.
For this upgrade, I will be following the guide presented here: www.dziedzic.us/wpc_speaker_replacement.html
Basically, I will be replacing the cabinet speaker with a woofer, and installing a pair of full range speaker in the back box. It won't be stereo, but it should be an improvement over the stock speaker system. My wiring when I am done will look like this:
Last night I went ahead and tore down the speaker panel. The speaker grills had to come off anyway because I need to re-paint them. [quoted image]
As you can see, The stock speaker was a 5.5" mid range with a 3" tweeter. I will be replacing them with a pair of Pyle PL63BL's. These are nice full range speakers that will fit well into the existing cabinet. The only bad part about this conversion is that I will have to cut the speaker panel to accommodate the 5.5" speakers on both side. [quoted image][quoted image]
No need to cut! You can use speaker adapter.
Example:
https://flipperfidelity.com/5-square-wood-adaptor-for-williams-bally-520.html
#52 5 years ago
Hmmm... That may be a possibility. My only concern is that it leaves the speaker partially covered.
#53 5 years ago
So I cleaned up the coin door yesterday. It wasn’t in too bad of shape, and just about everything came clean in the sonic cleaner.Almost doneAlmost doneReady for a bathReady for a bath
#54 5 years ago
So we had some warm weather today. I was able to escape to the shop and repaint the back board. I was also able to mount up my speakers for a test fit. I still need to repaint the speaker grills.C66BF83F-FF73-462E-A2A5-2CECF74673BE (resized).jpegC66BF83F-FF73-462E-A2A5-2CECF74673BE (resized).jpeg4A44B196-FF21-4701-B88B-EA6289BFE4A3 (resized).jpeg4A44B196-FF21-4701-B88B-EA6289BFE4A3 (resized).jpeg
It’s getting pretty close to done.
#55 5 years ago
This is great work, congratulations.
Being an FunHouse owner myself, I can only appreciate the amazing efforts you are putting into making this classic feel like new.
This is brilliant!
#56 5 years ago
So I wrapped up the speaker upgrade today...
First of all, I mounted the L pad in the head. A lot of people put it in the bottom of the cabinet, but I didn't see the point of running a lot of extra wire. However, this does mean to adjust the high end of the sound, you have to take the backglass off. The head speakers are then run off the right hand speaker port on J2 of the sound board.
The low end bypass filter was then mounted next to the subwoofer speaker in the cabinet. I used a 6 inch woofer so I didn't have to modify the cabinet to mount the speaker. I then connected this to J1 on the sound board. I re-used the cabinet wiring to get the signal down to the subwoofer.
So, does it work?.... OH YEAH! You bet it does. It does take a little tweaking to get right. You can increase the base by raising the machine volume, and then you can adjust the mid/high range by adjusting the L-pad in the back box. It is tempting to run a lot of base, but I quickly found it made the machine buzz too much. So I turned it down to the point where you could feel the base, but it was not trying to rattle Rudy's teeth out. It sounds much better. A lot of mid-range sounds that are complete lost in the stock setup come out nicely with the new speakers.
Next up... Rudy returns!!!
#57 5 years ago
So Rudy... He was a bit of a mess when I started. He looked like years of hocking the midway had taken its toll on him. His skin was mis-colored, and his eyes had faded to an ugly shade of yellow.
The inside of Rudy didn't look much better. I don't think he had ever been cleaned.
My original plan was repaint Rudy something close to the original factory colors. I am handy with an airbrush (see https://pinside.com/pinball/forum/topic/restoring-a-bride-of-pinbot-helmet ), and was planning on doing it myself. However, then winter set in here in the Mountains, and painting in my shop became nearly impossible.
So I recruited the modfather to bring Rudy back to life. I have to admit, I am not a fan of the blood shot eyed Rudy that he does, so I sent Rudy to Florida with the instructions to 'make him look stock'. Well Mod Father came through for me in a big way. Rudy's skin now looks more natural, and his eyes are no long yellow. In fact they look better than stock in my opinion.
57075679970__7FF2BC41-BB52-4A02-98BC-FBC5B09A348D (resized).JPG57075679970__7FF2BC41-BB52-4A02-98BC-FBC5B09A348D (resized).JPG
57075696571__C0C30114-E0E0-43FA-9EAC-98CDD4ECC3EB (resized).JPG57075696571__C0C30114-E0E0-43FA-9EAC-98CDD4ECC3EB (resized).JPG
So I cleaned up the insides with a bath in my sonic cleaner, and then did some polishing on the scoop. I think the insides cleaned up very well.
#58 5 years ago
So with the newly painted parts installed, Rudy went back into his place...
I do like the dark highlights in his hair now.
7477967E-5439-41C0-AB15-9895D6A209EA (resized).jpeg7477967E-5439-41C0-AB15-9895D6A209EA (resized).jpeg
So there you have it, one lightly modded Rudy.
#59 5 years ago
Wow he did a great job on those eyes, well done modfather!
#60 5 years ago
Well I am going to declare this one complete. Ive spent the last few weeks getting all the bugs out of it.
I learned a lot rebuilding this one. I had to deal with a new playfield for the first time, and found it was not as easy to install one as it seems. I continued to develop my cabinet painting skills. This one was fun.
Next on the list, I will be completing my Sorcerer.
#61 5 years ago
That is just incredible! Well done!
Where does it go now? Your gameroom or the classifieds?
I have to tell you...i am very excited about the sorcerer. I just love that pin.
#62 5 years ago
Quoted from Daditude:
It is actually going to a friend of mine. I wish I could keep it, but I have way too much money into it.
$ 29.95
13,000 (Firm)
Phoenix, AZ
$ 69.99
$ 22.50
$ 170.00
Displays
Digipinball Shop
5,500 (OBO)
Haledon, NJ
$ 15.95
$ 25.99
Lee's Parts
$ 40.00
$ 1,059.00
$ 25.99
Lee's Parts
$ 26.99
Lee's Parts
$ 399.00
Bethel Park, PA
$ 27.95
8,000 (Firm)
Reno, NV
$ 17.95
$ 14.95
$ 45.99
Lee's Parts
$ 59.99
$ 9.95
$ 225.00
Professor Pinball
This page was printed from https://pinside.com/pinball/forum/topic/yet-another-funhouse-restoration/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
